what air compressor for paint?
  • Thread starter Thread starter billison
  • Start date Start date Jul 9, 2006
billison
I like tinted tail
2,607
1,094
184
stl
Jul 9, 2006
  • Jul 9, 2006
in the next month or so i'll be getting ready for painting the mustang,
what i need to know is what am i looking for in a air compressor....
like do i need a min psi like 125 or 150
how big of a gallon tank do i need??? i'm new to air compressors
also anything special as i get a paint gun, gravity feed or just whatever, thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 9, 2006
  • Jul 9, 2006
You need a minimum of a 60 gallon tank and 5 HP for the motor. The paint spray guns are mostly low pressure (30-55 PSI) and high volume (10-20 CFM). Do a google search with http://www.google.com/search?hl=en&lr=&q=paint+spray+gun+air+Devilbiss&btnG=Search for more help.
http://www.spraygundepot.com/scripts/depot.exe?pgm=gunsdepotgate.bbx
http://www.autorefinishdevilbiss.com/paintcorecs.php
billison
I like tinted tail
2,607
1,094
184
stl
Jul 9, 2006
  • Jul 9, 2006
are you sure, that's like more than a 1000 conpressor, most have between 1-3 hp and less than 7 for the tank, sound outta place,
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 9, 2006
  • Jul 9, 2006
Go do some research, the Devilbiss site has the recommendations by the best paint spray gun maker.
Sample :
#66SD air cap Synthetic and acrylic enamels
Air Cap Pattern:
30-50 PSI inlet 7.9-12.1 CFM
Suction tips: 1.8 mm (66SS)
Order No.
Model No. 900345
46-6020
#66SK air cap Synthetic and acrylic enamels
More spray guns...
GTi® Millennium Gravity Feed HVLP Air Cap
#2000 air cap Base coats, clearcoats, primers, single
Air Cap Pattern:
4-10 PSI (air cap) 12.5-16.0 CFM @ 30 PSI inlet
Gravity Tips: 1.2 mm, 1.3 mm, 1.4 mm, 1.5 mm, 1.6 mm, 1.8 m
Order No.
Model No. 192136
GTI-407-2000
The 60 gallon, 5 HP compressor is a Home Depot special at about $400.
Too small a tank means that you run out of air volume and the pressure drops off. Then you have to wait for it to build up again. Not a good plan when your paint is curing inside the spray gun.
If the motor has limited HP, the compressor won't put out the volume needed to keep the tank pressure up. That means more waiting for the tank to fill up to the pressure needed to operate the spray gun.
GT_Rich
172
North Canton, OH
Jul 9, 2006
  • Jul 9, 2006
I have the second gun pictured (the GTI Millenium). It's a nice gun and comes with multiple tips to help you adjust to different conditions. Recommended pressures are 20-25 psi for base and 25-30 psi for clear. I stay on the low end of that and use either a 1.3 or 1.4 tip, depending on the temperature (higher the temp, the quicker paint dries, and the quicker you'll need to put it down, meaning bigger tip). I'd look into oil free compressors, as these will give more pure air with less contamination. If not, get a good inline filter.
billison
I like tinted tail
2,607
1,094
184
stl
Jul 9, 2006
  • Jul 9, 2006
ok, that makes more sence,
sunil6784
620
Boston, MA
Jul 10, 2006
  • Jul 10, 2006
I'd do some research on google and on the internet, like jrickher said. A compressor for painting, especially in something like a car where you want to minimize the imperfections, is a pretty big investement. You want a good compressor where it can provide a steady, clean stream of air. Cheap compressors usually don't have the hp or the capacity to do this.
If you look at the specs of those two paint guns, try to find a compressor to match the needs of the gun. Ideally, you want your compressor to handle a little more than the gun needs, just in case. I did a quick search on sears.com and the cheapest i found was 1200 dollars.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 10, 2006
  • Jul 10, 2006
You not only have to consider the pressure, which any compressor can deliver 30-55 PSI, but also the volume. Consider the flow available from a garden hose compared to a 3" firehose. At the same pressure, the fire hose puts more water. Even if you cut the pressure to the fire hose in half, it would still put out more water, .
SoCal89GT
75
Detroit, MI
Jul 12, 2006
  • Jul 12, 2006
Hear is a small thought that might help you, I have painted a bunch of cars in my garage at home and I learned to paint with a vacuum fed gun first then went to a gravity fed HVLP (high volume low pressure) the HVLP gun dumps much more paint and you need to move mush faster. I feel that they are easier to make mistakes with as well. I dont know how new you are into painting though so I may be preaching to the choir here. Or I could be crazy, so someone can correct me if I am wrong.
billison
I like tinted tail
2,607
1,094
184
stl
Jul 12, 2006
#10
  • Jul 12, 2006
  • #10
yeah that's something i needed to hear, i've only sanded and primed cars never paint, that's why i'm gonna have a friend help me paint someone eles car befor i do mine, lol, so i think i'll go with the vacuum fed if that's better for starters, and i can't do 1200 by a long shot, i'm only gonna have 200 maybe 3 for a compressor, so i gotta do alot of looking for the right oned thanks lots
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
T
A/C Compressor Reliability with Supercharger Setup – Need Advice
  • ThotTrap
  • Aug 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 29, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Anyone use a Chiller in their shop air?
  • limp
  • Sep 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2024
limp
