I cannot get this car to have any driveability whatsoever. I have narrowed it down to a few possible issues.
#1 how much does the computer (A9L) try to compensate for difference in clyinder pressures?? I have a high mileage 302 stock bottom end with whats in my sig below. Nothing too major. I did a compression test awhile back and had 2 cylinders that were within the % of spec but were lower than the rest. If I recall all were about say 120-130 and the other two were 108 ish. I am right on the within spec? Would the computer try to do different things to compensate for the differences and cause issues?
#2 How accurate is the intake temp sensor?? I just finished up install of a 2 core Procharger intercooler and took it for a spin. I have a LM-1 installed with rpm converter and with 1 of the channels I am recording intake temp. Now I live in FL. and it is hot and humid toady, but didnt see any difference in intake temp before and after? The sensor ohms out within its working range.I do see a difference when the methanol is injected. Intake temps around town with the intercooler were 220*. I just dont know if that is too hot causing the computer any issues? By the way on the smallest setting with methanol the intake temp reads about 180* after a full throttle long pull, say on the dyno. This was without the air to air intercooler installed. Thanks
