What are the arrows on the tires for?
I've noticed today that I've switched up the front wheels/tires because the arrows on the tires are pointing in reverse direction :doh: I must've switched it up while installing new struts.
Anyhow, does it hurt or anything if you switch it like that? If not, then why would they put arrows on the tires? :shrug:
You need to switch them back ASAP. The arrows show the rotational direction, and they do have a one-way rotation.
You'll be O.K. Don't worry about it.
I was cleaning my rims and tires and noticed that my left rear tire was mounted wrong from the factory. Go figure! :doh: I took it back to the dealer and they re-mounted it in the right direction. I didn't notice it 'til after I had already put 2,500+ miles on the car. I told the service guy that if I got any noise or vibration from it that I wanted a new tire. He told me if they noticed anything abnormal that they'd definately replace it. Everything is o.k. and it's been almost 3,000 miles since they switched it. I don't think you'll have anything to worry about. Relax, go put them back on right and have a cold one. :cheers:
I agree...definatley switch them asap. You may or may not notice abnormal wear problems...but you will hydroplane like a sunno***un. They are one way for a reason.
What I meant when I said "You'll be o.k. Don't worry about it" is. When you switch them back, if you havn't had them going in the wrong direction for a long time you most likely havn't cause any damage to them. Just thought I'd clarify myself. :nice:
