What are the chances that the head could be cracked?
TheBocSez
652
Converse, TX
I had an overheating issue that resulted in detonation and a blown head gasket. I nursed it home, bout 1/2 mile and will be replacing the head gaskets this weekend.
I was wondering what the chances are of a cracked head as a result of this?
The heads are Iron E7 Powerheads on an Stock block.
I know aluminum heads may be more prone to warping and cracking, what what are the chances with my iron heads?
Will I be ok, just cleaning the surfaces and bolting it all back together?
I was using Felpro 1011-1's will be replacing with Felpro 9333-pt1's and reusing my ARP head bolts.
Thanks.
They might or might not be damaged; I've blown head gaskets and my heads weren't damaged.
You should take the heads to a machine shop and get them cleaned up and inspected for damage. It'll prob. cost around $25-40 to have them hot tanked (cleaned up) and inspected.
I got mine cleaned up, valve seals and a 3-angle valve job for $100.
I second taking it to a machine shop, they will be able to find any cracks and clean them up. Also, I was under the impression that head bolts can't be reused because they stretch out once you torque them??
