What are the dimensions on the SN95 electric Fan
I have to replace the fan that is on my dads car and it has a 91 3.0L Taurus fan on it right now that is dead. I'm either going to get a Newer Taurus 3.8L Fan or an SN 95 Fan. Which one pull the most CFM out of these two Fans. I know on the 3.8L Taurus Fan the dimensions are 20.50 wide and 15.50 tall. I don't know what the dimension on the SN 95 fan.
They all use similar motors, so draw should be about the same. Difference maker would be fan blade pitch as to change the load on the motor.
Really, when choosing between any of the Ford OEM fans you are really just splitting hairs. They are all sufficient enough to cool a typical 5.0 engine and all draw approx the same.
Mark 8 fan is still the king, but i've no cooling issues with my SN95 fan and even have a 3.8L Taurus fan in reserve
I run a Mark 8 fan on my Mustang but it's an 18" fan and wont fit on my dads car. This is going in a Racecar. Right now it has the older 3.0 Taurus fan and the motor is dying. The blades barely move. I could just buy a new one just like it but it doesn't pull the air like the newer ones do. With just him driving the car the fan does just fine. But since my Falcon motor is blown up we both have been racing it. I also don't want something that will drain the battery. It does have a small alternator on it and if we have time between round we put the charge on the car. I'm most likely going to get the Taurus 3.8 fan because I know the Shroud will fit the radiator no problem.
