What are the small shocks in the rear called?
Funanin
356
Horsham, Pennsylvania
I was changing out my rear shocks and noticed these smaller shocks that are mounted sideways, I guess to help with traction. I took them off and they are roasted so i need new ones, but when i typed in the part number on motorcraft.com, I couldnt find anything. I dont even know what they are called so I cant call somewhere and say I need these because they wont know what im talking about. I think they might be called stabilizer shocks or something. Anyone know for sure and where I might be able to get new ones? :shrug:
i have also seen stabilizer shocks or stabilizer dampers, but i cant remember what site i was on. i might look them up on some resto parts sites to see what they call them - then ya know.
KYB sells them also.
good luck.
I had one on my car that went bad way back in roughly 1991.The Ford dealer wanted like $250.00 for a new one back then.I told the dealer to keep it and called up a local Toronto area Mustang performance shop that also kept good stock parts off of cars they had modified.I got one for $20.00 cash that was like new.Try some used Mustang parts places or performance shops to see if they have one lying around.
I believe quad shocks or axle dampers are common terms to describe them.
When I replaced mine a lot of auto stores did not know what I was talking about when I referred to them as quad shocks. I forget what they were called though. Just search around, im sure you'll find it.
The quad shocks are designed to prevent wheel hop and axle windup. Most guys that have aftermarket LCAs just ditch them since the LCAs take care of the wheel hop issue.
I am gonna try to get some at work tomorrow, (ford motorcraft warehouse) but the thing is I couldnt find replacement ones on motorcraft.com, so I dont understand why they wouldnt carry them or make them if they are part of the suspension on stock mustangs from 79-04?
Cjponyparts.com sells them for, 33.95 Each.
1984-2000
KYB Shock
Rear KYB quad shock
KYB20
33.95 Each
(will fit 79-84 w/8.8 rear differential)
The Koni Rear Quad Shocks are more expensive...
yb.dll
1985-2002
Koni rear quad
KONI10
199.95 Pair
