What are these plugs for?
boostfrk
712
69
59
Colorado
I've got a handful of plugs/wires on my '90 LX 5.0 that aren't connected to anything and I don't know what they go to. The car was a 4-banger converted to 5.0, so I'm wondering if some of these have to do with that. I don't have a constant CEL, but it comes on frequently. Sometimes it comes on for 5 seconds, and other times for 15 minutes. See the last 2 pictures about the test connectors.
The car runs fine from what I can tell. Even when the CEL is on the car doesn't run poorly.
The first group is back by the firewall, behind the strut tower on the RH side of the car. The smog system was removed at some point, so I'm guessing these might go for it?
The next several air by the filter, about 12" behind the headlight.
The last two are against the firewall on the left hand side, right behind the strut tower. This is where I have been looking for the test connectors so I can check the CEL codes, but I can't find the STI connector for the life of me.
1st two pics- EGR / Vacuum hoses. Are you running the EGR and smog equipment?
2nd pic- connector by the passenger headlight, not sure.
Last two pics- Those connectors are for an handheld tester, tuck those away.
VibrantRedGT - The smog system was removed by the PO.
90lxcoupe - I agree that the large white box looks like something a relay would plug into. Question is, a relay for what and where do I get the right relay?
wythors - That's what I thought too. The handheld testers I've seen require that you plug in both the traingular one on the STI connector, which I can't find. At first I thought the very last picture was the STI connector, but it's a 2-wire connector and everything I've read says the STI connector is 1-wire.
Looks like I'm down to pictures #2, 3 and 4, as well as finding out where the heck the STI connector is.
Thanks! More replies appreciated!
(I hate Electrical)
First picture: EGR Vacuum regulator connector, TAD & TAB Smog pump solenoid connectors, vacuum lines for EGR and Smog pump actuators.
Second picture: The relay is probably for the A/C WOT cutoff, which turns the A/C compressor off at Wide Open Throttle (WOT).
Third picture: connector up near the hood prop is probably for the air bag crash sensor.
Fourth picture: may be for the canister purge solenoid connector.
The cone air filter in the engine compartment is a big no-no. It sucks up hot air from the engine and the turbulence from the fan cause airflow problems through the MAF. The stock airbox will make much more power that the setup you now have.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
The guy you bought the car from must have been metally retarded. Removing the pollution control equipment from a 5.0 Mustang is a bad idea. All you have accomplished is to make the computer mad and spit codes. The pollution control equipment all shuts off at wide open throttle, so the HP losses from it on the car are 2-5 HP. The catalytic converters may soak a few more HP than that. None of the pollution control equipment reduces the HP enough to cost you a race in anything but professional drag strip competition. I doubt that the car will be in the top runoff for "Pinks", so he did harm to the car and you by his efforts.
Know what does what before removing it. Remove or disable the wrong thing and the computer sets the check engine light and runs in "limp mode". Limp mode means reduced power and fuel economy.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...e to check cars, but it is still Federal law.
I'll pull back some of the loom around the self test connector and try to find the STI. It has to be there somewhere.
Keep in mind, I didn't remove any of this stuff. I'm trying to put this back together to as close of a stock car as possible. If I could find a stock smog system and a stock airbox intake system I'd probably buy them and put them back in, just so I could get it back to how it's supposed to be.
I've spent the morning off and on checking all wire looms near the driver's strut tower, firewall, etc. and can't find the STI grey connector, a white/red wire (color I have seen it's supposed to be) that's not already connected to something, or any other loose/broken wires that may be the STI.
Is there ANY other way to check the codes?
Check your diagnostic connector for four wires. It should only have three. The wire at the top of the picture that looks W/P should not be there. That may be your STI wire.
I do have 4 wires at the diagnostic connector. When looking at the female end of the connector (side opposite the wires) colors are as follows:
Bottom row:
Far Left: White w/ purple stripe
2nd position: White w/ green stripe
3rd position: Empty
4th position: Blue w/orange strip (2 wires going into this slot)
Top Row:
Left: Empty
Right: Grey w/ red stripe
Given the fact that none of these colors match the ones listed below, how do I determine which wires I need to jumper together to read the codes? I DO NOT want to fry something and have to go replacing parts. OEM parts are hard enough to find.
The W/P wire is your STI wire. Someone must have lost the grey connector and just snapped it into an empty spot in the VIP connector.
The color of the wires isn't as important as the position of the wires in the connector especially if your using a code reader. If the position of the wires in the connector are correct the diagrams above will work.
Your PK/LG must have faded to a W/LG.
It appears that the location (and colors) of my wires matches up with the 5.0 picture that you attached, and the STI wire was just plugged into one of the empty slots as you said.
Looks like I'll want to jumper the W/P wire and the GY/R wire as that matches the locations shown in the pictures above that jrichker posted. I'll try to read the codes tomorrow.
THANK YOU!
