My last car was an 2001 Mineral grey delux Gt and it carved corners. Bilstein Hd's all around with Steeda Sports Poly spring isolators, X2 balljoints,off-set A arms,Aluminum off-set steering rack bushings,Steeda cm strut brace,Cobra sway bars front and rear with poly D bushings,Steeda caster/camber plates,2000 Cobra R's on Nitto nt555's. C&L 80 mm air mass,plenum spacer,70 mm t.b.,Magnaflow 2.5 catted X pipe with welded in magnaflow mufflers,Steeda underdrive pullies,Superchip,160 deg T stat,Steeda tri ax,adjustable clutch cable,firewall adjuster,and hardcore quadrant,Autopower 4 point cage,Steeda cm sub frames
My 2004 silver premium Gt sports a Centerforce II 70 mm t.b. Steeda Cai. Awating install is my Magnaflow X, Steeda tri ax,Jba 1 1/2 shorties,Powerslot/hawk combo for the rear,Steeda strut brace. I want to make this car an all arounder just most of you guys,it is my daily driver for now but as it becomes paid off and older I want to make it a drag car with something like a 5.4 2v with a kb 2.2 pushing as much boost as possible and then some
