What backspacing for Welds? Small front and 8" rear? Got pics?
  • Thread starter Thread starter BelueLX
  • Start date Start date Jun 10, 2004
1 of 2 Next Last
BelueLX
1,195
  • Jun 10, 2004
What wheel back spacing and rim width do you use on your 5.0? I want Weld Draglites-- I guess 3.5" or 4" skinnies for the front and my slicks are 26/8.5 . Got pics?
Thanks,
Cody
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 11, 2004
  • Jun 11, 2004
Fronts for skinnies would be 3.5" -- only one backspacing made, for the rears sounds liek 8" wide, with 5.5" backspacing.
Qwk88LX
202
21
Sunrise, FL
Jun 11, 2004
  • Jun 11, 2004
Here's mine.. skinnies up front (3.5 backspacing), 15x8's (4.5 backspacing) in the back with 295/50's..will be switching to 15x10's with 295/65 BFG drag radials so I can switch to 4.10's
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 11, 2004
  • Jun 11, 2004
You sure you're going to run a 30" tire on there?
Anyway, for your 10" rims I'd run 6.5" BS. I like to have the rims tucked underneath -- that's why I like 5.5" BS on 8 and 9" rims as well.
Qwk88LX
202
21
Sunrise, FL
Jun 11, 2004
  • Jun 11, 2004
well I already tucked in my fenderwells, removed the quad shocks & I also have air bags, so I'm not worried about clearance..the airbags are completely deflated in the pic & I still have plenty room. I'll probably go with a 5.5" backspacing..I don't mind the aggresive look with the tires sticking out a little. Plus I want to go with a tall tire to compensate for the high gears when I go with 4.10's since I have a C4.
edit: I forgot to mention that since I did the C4 swap, I had to use a longer driveshaft & that jacked up my rear-end even more.
BelueLX
1,195
  • Jun 11, 2004
what size are your front tires. like 165/65/15 or 175/75/15 or something like that?
Qwk88LX
202
21
Sunrise, FL
Jun 11, 2004
  • Jun 11, 2004
they're 165R15's
BelueLX
1,195
  • Jun 11, 2004
is that like a 165/80? i cant find 165R15s on tirerack.com or discounttiredirect.com . have to enter the aspect ratio i guess...
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jun 11, 2004
  • Jun 11, 2004
Go to Pep Boys, I think they are like $40 all together.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 12, 2004
#10
  • Jun 12, 2004
  • #10
I was talking about clearance from the fender lips to the tire. Your car must not squat at all when you launch -- all the cars I've had with 26" tires either come close or rub on the fenderlips, and you're running about a 26.5" tire -- that's why I like them tucked in as much as possible (other than the look). Most cars that would run a bigger tire would find a 28" tire and be fine, a 30" tire I don't know how you would really fit without fenderwell modifications with the widths they come in. BTW -- I'm running 4.30's and deciding between a 26" tire and a 28" tire (I have 26" tires right now).
Oh, about the driveshaft -- there's no reason why a longer or shorter driveshaft would change the height of the car, I think you're mistaken there. The driveshaft has nothing to do with suspension height.
D
dude5l
201
Grande Prairie, Alberta , Canada
Jun 12, 2004
#11
  • Jun 12, 2004
  • #11
I was wondering about the driveshaft statement myself, what makes you think it effected your ride height?
84blkstang
544
Springfield MO
Jun 12, 2004
#12
  • Jun 12, 2004
  • #12
Not to steal the thread but i am going to get some 8 inch welds in the back and 7's upfront wha backspacig do i need to have no cleareance problems and i dont want them sticking out either, also what size tire should i run in the back when i get these i have a 215 70 15 now and i dont like the way they look. any comments opions are appreciated
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 13, 2004
#13
  • Jun 13, 2004
  • #13
For the 7" rim, 4.5" BS is as close as you can get -- but be aware you may have some clearance problems between the caliper (bolts) and the wheel -- the welds don't have alot of room inside. It's not a huge deal, grinding a little on the bolt will fix it.
Stock size tires would be 225/60-15...you can run that up front or a little skinnier tire like a 215/65 or so. The back you can run a 265/50 or a 275/50 and it will work well and fit nice.
Again, in the back you may have some clearance issues, but it will be between the exhaust and/or quad shocks. Just a little adjustment or flipping the shocks will fix it.
They may fit right on, they may need a little adjustment -- I've had them go both ways.
84blkstang
544
Springfield MO
Jun 13, 2004
#14
  • Jun 13, 2004
  • #14
does anyone have a pic of the tire sizes mentioned above on a non lowered stang? Also doesnt the 84 have smaller brakes then the rest of the 87-93 stangs?
dartman
121
cardboard box
Jun 13, 2004
#15
  • Jun 13, 2004
  • #15
I GOT 83 GT WITH 15X10 IN REAR WITH 6.5 BACKSPACE..WILL TRY TO POST A PIC ,,IF I KNOW HOW?????? I GOT HOOSIERS 27X11.50X15 ON REAR....BUT IF YOU GOT 26X8.5 TIRES I WOULD GO WITH 5.5 B/S WITH 8 IN RIM..SORRY PICS TO BIG....
hllon4whls
BANNED
2,567
Covington
Jun 13, 2004
#16
  • Jun 13, 2004
  • #16
Red Stick, La:
You can use paint to shrink the heck out of any pic. Go to image, stretch/skew. Then keep the horizontal and vertical at the same ratio. 30% will likely get you there. Dont forget to save a copy so you can have a full size and mini-me version.
5.0_Gil_89
163
Germany
Jun 13, 2004
#17
  • Jun 13, 2004
  • #17
A guy I know was running 4.10's with a 28" tire and it was bogging the hell out of the motor till it was running up top. If your going to go that tall 4.30-4.56 would be my choice. But if it's to kill some gear for the street that would be a good move. Oh! with the 295's are you running dumps? Later and be safe.
Qwk88LX
202
21
Sunrise, FL
Jun 14, 2004
#18
  • Jun 14, 2004
  • #18
Yeah my car doesn't squat that much, I have stock suspension out back minus quad shocks. Well I probably would go with a 6.5 backspacing to play it safe, my fernderwells are rolled back about 50%, I would roll them back all the way before running bigger tires. Where did you get the 4.30's from?..see below about d/s.
I guess I could be wrong about the driveshaft, but before the install my tires would slightly rub against my fenderwells with the airbags deflated, but now even with them deflated I still have enough clearance to not rub ..anyone have any other explanation, I'd be glad to hear it..
I don't know about that low of a gear..I might consider 4.30's. I have a C4 (no overdrive), & the car is street driven quite a bit..Yes, I'm running dumps & I also removed my quad shocks.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 14, 2004
#19
  • Jun 14, 2004
  • #19
I got mine from Summit -- I think I might have had them price match Diversified when I got a bunch of stuff from them last time. They're a standard FMS gear.
Qwk88LX
202
21
Sunrise, FL
Jun 14, 2004
#20
  • Jun 14, 2004
  • #20
cool, thanks..I might have to try them out. guess I never noticed them before coz I never considered putting them on my car.
edit: nice ride! you sold it?? whyyyy?
1 of 2 Next Last
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:18 PM
2000xp8
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
