Qwk88LX said:Here's mine.. skinnies up front (3.5 backspacing), 15x8's (4.5 backspacing) in the back with 295/50's..will be switching to 15x10's with 295/65 BFG drag radials so I can switch to 4.10's![]()
89MustangGX said:You sure you're going to run a 30" tire on there?
Anyway, for your 10" rims I'd run 6.5" BS. I like to have the rims tucked underneath -- that's why I like 5.5" BS on 8 and 9" rims as well.
they're 165R15'sAXIStang said:what size are your front tires. like 165/65/15 or 175/75/15 or something like that?
AXIStang said:is that like a 165/80? i cant find 165R15s on tirerack.com or discounttiredirect.com . have to enter the aspect ratio i guess...
Qwk88LX said:well I already tucked in my fenderwells, removed the quad shocks & I also have air bags, so I'm not worried about clearance..the airbags are completely deflated in the pic & I still have plenty room. I'll probably go with a 5.5" backspacing..I don't mind the aggresive look with the tires sticking out a little. Plus I want to go with a tall tire to compensate for the high gears when I go with 4.10's since I have a C4.
edit: I forgot to mention that since I did the C4 swap, I had to use a longer driveshaft & that jacked up my rear-end even more.
89MustangGX said:Oh, about the driveshaft -- there's no reason why a longer or shorter driveshaft would change the height of the car, I think you're mistaken there. The driveshaft has nothing to do with suspension height.
84blkstang said:Not to steal the thread but i am going to get some 8 inch welds in the back and 7's upfront wha backspacig do i need to have no cleareance problems and i dont want them sticking out either, also what size tire should i run in the back when i get these i have a 215 70 15 now and i dont like the way they look. any comments opions are appreciated
dartman said:I GOT 83 GT WITH 15X10 IN REAR WITH 6.5 BACKSPACE..WILL TRY TO POST A PIC ,,IF I KNOW HOW?????? I GOT HOOSIERS 27X11.50X15 ON REAR....BUT IF YOU GOT 26X8.5 TIRES I WOULD GO WITH 5.5 B/S WITH 8 IN RIM..SORRY PICS TO BIG....![]()
Yeah my car doesn't squat that much, I have stock suspension out back minus quad shocks. Well I probably would go with a 6.5 backspacing to play it safe, my fernderwells are rolled back about 50%, I would roll them back all the way before running bigger tires. Where did you get the 4.30's from?..see below about d/s.89MustangGX said:I was talking about clearance from the fender lips to the tire. Your car must not squat at all when you launch -- all the cars I've had with 26" tires either come close or rub on the fenderlips, and you're running about a 26.5" tire -- that's why I like them tucked in as much as possible (other than the look). Most cars that would run a bigger tire would find a 28" tire and be fine, a 30" tire I don't know how you would really fit without fenderwell modifications with the widths they come in. BTW -- I'm running 4.30's and deciding between a 26" tire and a 28" tire (I have 26" tires right now).
I guess I could be wrong about the driveshaft, but before the install my tires would slightly rub against my fenderwells with the airbags deflated, but now even with them deflated I still have enough clearance to not rubdude5l said:edit: I forgot to mention that since I did the C4 swap, I had to use a longer driveshaft & that jacked up my rear-end even more.
I was wondering about the driveshaft statement myself, what makes you think it effected your ride height?
..anyone have any other explanation, I'd be glad to hear it..I don't know about that low of a gear..I might consider 4.30's. I have a C4 (no overdrive), & the car is street driven quite a bit..Yes, I'm running dumps & I also removed my quad shocks.5.0_Gil_89 said:A guy I know was running 4.10's with a 28" tire and it was bogging the hell out of the motor till it was running up top. If your going to go that tall 4.30-4.56 would be my choice. But if it's to kill some gear for the street that would be a good move. Oh! with the 295's are you running dumps? Later and be safe.
Qwk88LX said:Where did you get the 4.30's from?
cool, thanks..I might have to try them out. guess I never noticed them before coz I never considered putting them on my car.89MustangGX said:I got mine from Summit -- I think I might have had them price match Diversified when I got a bunch of stuff from them last time. They're a standard FMS gear.
