Like the title says, I have an exide in mine now, it fell over a couple of weeks ago, and I put more acid and water in and gave it a full day charge, and it lasted one day, So what would be a good batt. for my stang, I need something strong alot af cranking amps, an 800 cranking amp power wont even turn the starter motor over, so you get the idea. My car has about a 10.5 comp. ratio I believe, definately not the stock 9.0. Also the alternator dosent like to charge alot, I have the fuel pump switch on the battery, and it runs right off the batt, so if I hooked that to the terminal in the engine bay, would that help in the charging?
Thanks Josh
Thanks Josh
