what cam
ENGINE
Block bored 30over
331 Stroker
185cc AFR heads
Spyder intake w/power elbow
75mm Throttle Body
80mm Mass Air Meter
EXHAUST
Mac Long Tube Headers 3" Collectors
X-pipe 3" With Cat
super 40-series mufflers
FUEL
Complete 700horse aeromotive system
36lb/hr injectors
IGNITION
MSD 6AL
FRPP wires 9mm
SUSPENSION
90/10 struts
50/50 shocks
Eibach Drag Springs
Upper+lower Control arms
Subframe connectors
4-pt k-member brace
Strut tower brace
No swaybar or quad shocks
I am looking for a good streetable cam.. I want to run in the 12s or 11s.(possible with my combo?) If you have anyother suggestions or things i should add to my combo put your 2cents in please. O, and what kind of horse/torque??
ucanbeatme said:
ENGINE
Block bored 30over
331 Stroker
185cc AFR heads
75mm Throttle Body
80mm Mass Air Meter
EXHAUST
X-pipe 3" With Cat
FUEL
36lb/hr injectors
IGNITION
MSD 6AL
FRPP wires 9mm
SUSPENSION
90/10 struts
50/50 shocks
Eibach Drag Springs
Subframe connectors
4-pt k-member brace
Strut tower brace
Well I would want to consider getting a different intake.. There are many better matched intakes out there then you are planning to run that will perform much better for your car.. I also think custom is the best way to go as I know you have to pay a little extra but there are worth it and aren't much more then other cams.
www.flowtechinduction.com
With a custom cam I don't see why with a good chassis and driver you couldn't dip into the 11's
Yep...go with a custom cam...
The prices (as stated) aren't much higher...take Ed Curtis (FTI) for example...his HR cams are $325...now compare that to the price of an alphabet cam ($160-$200) your paying roughly $125 more but for better driveability/power/customer service...worth it IMO...
