Fox What cheapish mods can i do to increase horsepower/torque?
Do you still have the stock air box? I just learned a few days ago that my car still had the air silencer. Supposedly removing it can net 5-10 horsepower.
If you have an aftermarket midpipe in your exhaust you can remove the smog pump (thermactor pump) and run a shorter serpentine belt.
I don’t recommend under drive pulleys.
You already have good rear end gears, so from this point I would say start saving up for heads, a cam and upper/lower intakes.
Reactions: 5.sloww
Hey i have a black 1990 lx 5.0 thats basically stock. All it has is koni shocks and a 3:73 gear ratio. I was wondering what other mods you guys recommend to up the horsepower and torque. Thanks :)
You got any money? If not, bumping timing and gears is the best you can do on a stock 5.0 without buying and replacing parts. The gears you have so bump the timing. I was able to run 13.5* and stay on 87 octane. Running 91+ octane isn't worth squat on a stock engine.
If you want more, acquire about $3k, and we can give you endless suggestions with what do to with it.
Lets see some pictures of your car!
:worthlesb
Reactions: 5.sloww
Long tube headers will help get a little more torque... intake will help a little horsepower ....
You have the gear...so...a decent camshaft would help torque and hp. That's a more complicated route...and you'll need rockers and springs..and maybe push rods too.
Hi there. Lots of good suggestions here. I also have a '90 LX also and here are the things I did:
- remove the bug screen that's part way up in the air intake upstream of the MAF, it restricts the flow
- put a K&N air cleaner in the stock air intake. Less expensive than a cold air intake and you can tell the difference
- under drive pulleys. I got a noticeable bump with these (5-7hp) with no impact to charging or cooling
- better ignition. I installed a Performance Distributors system which was hotter coil, TFI card with longer dwell, and their "live wires" spark plug wires. You can increase spark plug gap. Got a nice bump out of this change
- you have headers and X pipe already, replace the stock mufflers with performance mufflers, I installed Magnaflows
- run synthetic motor oil, that increases hp as well compared to non-synthetic oil
You can also put in a larger throttle body. I haven't done this but it's easy to do and the computer brain will adapt to the larger tb and deliver more fuel to the injectors.
Years ago, Mustangs and Super Fords magazine had a series of three articles with progressive changes that can be made to the Fox to boost performance. It started with some of the easy stuff in the list above and progressed to intakes, heads and cams. After each round of changes, they ran dyno checks and provided the results.
Reactions: 5.sloww
Welcome to Stangnet. Please do not post while drunk bro! :cheers: :D
You must have had a bad experience with under drive pulleys. I haven't. I installed mine around 8 years ago and as I indicated in my post, no problems with charging or overheating. Just free additional power.
I'm thinking that some under drive pulley sets have more aggressive ratios than others, that's something to think about.
Reactions: GTVin and 5.sloww
We all consider each other as friends on this site. Friends don't let friends do underdrive pullies.....or longtubes. You can thank me now....or later. Up to you. :cool:
well this shows where I stand around here.
i also have both
and I will say underdrive pulleys are well known for charging/high temperature issues, you can change the pulley on the alternator to help but then you chance over charging at highway speeds. My car runs warmer idling in traffic.
as for long tube headers, I have run them all my life, with the new style mini starter will make starter changing easy, now how often do you change the starter anyway?
Reactions: aztecgwynn
I've had underdrives on my car for 20 years. I've never had issues.
Granted, I addressed the issues before the problems ever started. My charging and cooling systems are pretty healthy.
I have pulleys on my car too, and every other Mustang Ive had, never had an issue during the day, just at night. I guess my cooling system is good enough. I don't drive much at night but when I do, you could tell they affected the charging system. Dim lights, slow signals, weak blower while they are all on sitting at street lights. Ill probably pull them off when I get my car home, that does get on my nerves. We'll see.
I have pulleys on my car too, and every other Mustang Ive had, never had an issue. I guess my charging and cooling systems are good enough. I don't drive much at night but when I do, you could tell they affected the charging system. Dim lights, slow signals, weak blower while sitting at street lights. Ill probably pull them off when I get my car home, that does get on my nerves. We'll see.
Not trying to be a dick here, but you say never had an issue and then list off a bunch of issues, lol.
UD pulleys aren’t the devil by any means, but you will notice dim lights at night, especially with your heat/ac and radio on. There is a reason people do 130 amp alternator upgrades.
That being said, anyone that wants them, go for it! Mercia!
