  • SN95 4.6L Mustang Tech
What could it be
  • Thread starter Thread starter 00GTpony
  • Start date Start date May 5, 2008
00GTpony
162
  • May 5, 2008
If my car is sitting idling for more than like 2 min, it will start to make like a putter sound out of the exhaust for like a min then go back to normal idle... It almost sounds like its got a mild cam, or it randomly misfires for a min then goes back.. its driving me crazy!!!!
40th GT
916
Lawrenceville, GA
May 5, 2008
  • May 5, 2008
When was the last time you changed your fuel and air filters?
Have you Seafoamed it yet?
Have you cleaned the IAC?
00GTpony
162
  • May 5, 2008
Fuel and air filter recent.... havnt cleaned iac yet
R
Roos85
125
Maryland
May 5, 2008
  • May 5, 2008
Seafoamed it? WTF is that
04fullitgt
I shower with poo
Nov 13, 2006
Crest Hill, Illinois
May 5, 2008
  • May 5, 2008
:search:
twogts4us
4,188
12
79
Dunedin, FL
May 5, 2008
  • May 5, 2008
Oh jeezus, you don't need to pour that crap in your motor. While I know many people think it's 'just great' and impress their neighbors (with the smoke show using this product produces) in the trailer next door, I honestly believe you can do more harm than good using it, especially on an older car. And let's face it - a 2000 is 8 years old, probably pushing the century mark in miles. In effect, you're attempting to overhaul the motor with a liquid. I'd suggest that if you are set on using this stuff (for what reason, I still don't understand), then I'd strongly recommend doing a compression test both before and after. My point? Sometimes removing residual carbon build up is NOT a good thing, especially if you don't intend to tear the motor down afterward and replace rings, etc.
If you wish to search for "Seafoam", just google for "Snake Oil" - same thing.
There was a TSB for this condition you've described, 00GTPony - Check here...http://mach1registry.org/forums/showthread.php?t=8375 and in particular, this TSB - http://www.mach1registry.com/database/uploads/ENGINE%20MISFIRE%20OR%20ROUGH%20RUNNING%20.pdf
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
