I just put the heads on my new engine and installed the lifter and rockers. I am using E7 Powerheads with the Crane Cams stud conversion kit installed. I installed new FRPP stock length pushrods and Crane Energizer Roller rockers.
I adjusted the rockers using the method outlined here:
http://forums.stangnet.com/showthread.php?t=542361&highlight=adjusting+roller+rockers
Starting at #1 when the exhaust 1st started to open, I adjusted the intake by twirling the pushrod until resistance was felt the I adjusted the lock nut between 1/2 and 3/4 turn and secured it with the poly lock.
I then rotated the engine until the intake valve on the same cylinder was almost fully closed and I adjusted the exhaust using the same method and number of turns.
I repeated this process on the remaining cylinders in the firing order until all 8 were done.
The reason I think something has to be wrong is that I see a lot of post asking how to adjust roller rockers and it didnt seem like that big of a task. Actually went pretty quick.
There is some light side to side movement on the rockers when they both closed but I assume that will tighen up when the lifters are pumped up.
So, what did I do wrong or is it just one of those things that is made out to be harder than it is??
while I have you here, when I installed my head gaskets, As long as I put the word front to the front, there should be no issues correct? I used the Felpro 1011-1 (think thats the #)
