  • SN95 4.6L Mustang Tech
What direction to go?
  • Thread starter Thread starter FavreOnSunday
  • Start date Start date Apr 28, 2008
FavreOnSunday
  • Apr 28, 2008
I have a '96 GT 'Vert. I've done the pi intake swap, bassani x w/cats, Magnapacks, & MGW short throw. I've already bought a set of pi heads, & I have a set of Steeda u/d pullies waiting to go on. My hp goal is roughly 300. This is my daily driven car, & I have emission in Ga. I was close to buying a set of Comp 270 cams, but a concern for passing emissions came up. So, I'm not sure exactly what direction to go. Should I do the pi head swap, & get a set of cams to go with them, or just put a set of cams in my npi heads. I also know I need gears, & eventually long tubes.
D
darkside03gt
851
Sacramento CA
Apr 28, 2008
  • Apr 28, 2008
If your goals are 300rwhp. get the comp stage 2s with your pi heads. you will never see 300 without pi heads. comp reccomends 355 or better gears for those cams. dont waste your money on cams for your npi heads.
FavreOnSunday
  • Apr 28, 2008
Are Comp 270 cams, Stage 2 cams. ....Also, what the chances on those cams triggering my CEL? I was assuming 3.73 gears, although I know everyone say 4.10. I drive from Ga. to Fla. sometimes, & was thinking the 3.73"s would be better.
FavreOnSunday
  • Apr 29, 2008
bump
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Wednesday at 6:44 PM
DadLife0724
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
