nos707 New Member Sep 25, 2005 108 0 0 UK Sep 28, 2005 #1 Sep 28, 2005 #1 Hi guys, I have the Holley Systemax 2 kit. What do I set the lash to? The Lunati manual says 0.10 - 0.20! That not much help really! Does anyone else run the same kit? (Heads, Intake, Rockers, Cam)
Ourobos Member Apr 12, 2004 260 1 17 Sep 28, 2005 #2 Sep 28, 2005 #2 Did you get the pedestal mounted heads, or the stud mounted heads? IF pedestal, just torque to spec. If stud, try 1/4 to 1/2 turn past..
nos707 New Member Sep 25, 2005 108 0 0 UK Sep 28, 2005 #3 Sep 28, 2005 #3 It is the rocker lash I need to know! I have the Lunati roller cam and rockers.
srothfuss Last night I stabbed the same guy 7 times in a row Oct 17, 2004 1,796 3 0 Woodward Ave. Sep 28, 2005 #4 Sep 28, 2005 #4 Behold.... The power of the search button! Installation Tips by 5spd GT You can read down near the bottom of this wonderful write up to find the information you are looking for.
nos707 New Member Sep 25, 2005 108 0 0 UK Sep 28, 2005 #5 Sep 28, 2005 #5 Thanks Ourobos! So, basically you dont set the lash with a feeler guage but just with a 1/8 or 1/4 turn? Im more used to setting the lash with the feeler guage, then locking the rocker down. This is my first 302, I usually work on a 706.
srothfuss Last night I stabbed the same guy 7 times in a row Oct 17, 2004 1,796 3 0 Woodward Ave. Sep 28, 2005 #6 Sep 28, 2005 #6 You want to tighten the rocker to a point when the pushrod no longer turns freely with two fingers (general rule) follow the instructions listed above and you should be OK.
nos707 New Member Sep 25, 2005 108 0 0 UK Sep 28, 2005 #7 Sep 28, 2005 #7 Thanks srothfuss! I'll let you know how I get on!!
