What do I fix first?
  • Thread starter Thread starter alextank8
  • Start date Start date Apr 12, 2011
1 of 2 Next Last
A
alextank8
  • Apr 12, 2011
Hey guys I need some help Please.
Here are the following things I have to do to my 65 fastback project in order to get in running, but I have no idea where to start.
- Rewire entire car (previous wiring ripped out)
- No trans. (I have a 302 manual engine)
- Redo brake system (no idea how or where to begin with this)
- Both doors need work but I can get by for a while
- New interior (probably going to buy an interior kit)
- needs the rear section of the r/s rear frame rail where the back of the leaf spring bolts up to
- both side trunk floors
- gas tank
- section of the trunk floor that goes from where the gas tank bolts to up to the openings for the rear shock access holes
- r/s inner wheel house
- r/s quarter panel assembly (I'm sure this could wait as well)
- and lastly I plan on rebuilding my 302, but not sure what order to do this stuff in
Any help or advice is greatly appreciated.
Thanks
Alex
2+2GT
3,333
10
79
Southeastern Pennsylvania
Apr 12, 2011
  • Apr 12, 2011
Do this first
No such thing. Stick a pilot bushing in the crank, it's a manual. Take it out, it's an auto.
- gas tank
Do this last-
robbz28
775
Epps, LA
Apr 12, 2011
  • Apr 12, 2011
step 1...if you are married, build a doghouse, because you will be spending more time with your car than your significant other, lol....then do everything that 2+2 said.
A
alextank8
  • Apr 12, 2011
haha no don't worry i'm only 17 my dads going to help but not kill himself over it,
and 2+2 i didnt mean my engine was a manual my bad i just didnt put in a comma, i'm pretty sure a manual tranny would be cheaper but correct me if i'm wrong, and do you know how i would go about the frame rail or where i could get one i'm not really understanding what to do here.
robbz28
775
Epps, LA
Apr 12, 2011
  • Apr 12, 2011
Sounds like the butt of your car is pretty rotten...don't worry because this is not a rare problem. Some pics would help out, but from what i can gather your car may be a candidate for an entire floor swap....these panels are reasonable, but are a MAJOR chore....but it can be done, even by a first timer. You will need to strip your car down, take it all apart, tag and bag all of your parts, take lots of pictures. Tear it down to the basic body and put it up blocks and start to work on the body. Pour some water in the cowl vent in front of the windshield and see if water ends up on the floorboard, if so then you will need to address the cowl rust as well, may be minor, may be major (mine was major). Just ask plenty of questions, google is your friend, were all here to help, have fun!
rbohm
6,698
550
204
tucson,az
Apr 12, 2011
  • Apr 12, 2011
i would start by getting rid of any rust in the body/chassis. if this isnt done, then the rest of the work is flushing good money after bad.
next i would do suspension and brakes.
after that drive train
wiring
paint and body
interior and other details.
A
alextank8
  • Apr 12, 2011
here's the link to the pictures. He said he just replaced the cowl so I don't think and am hoping there shouldn't be a problem with that. Also it looks to me like the trunk floor is the only bad floor part, the rest looks pretty good i guess but i'm not an expert so i dont know.
Thanks guys
http://www.kodakgallery.com/ShareLanding.action?c=9828gbeq.3qj65fby&x=0&h=1&y=wmfehw&localeid=en_US
Above is link to pics
2+2GT
3,333
10
79
Apr 13, 2011
  • Apr 13, 2011
In your place I'd use a T5 5-speed. Start shopping now, for a deal on a T5. You can get rebuilt ones for $950, so if you can get a decent used one for half that…
mustangmutt
339
El Paso, TX
Apr 13, 2011
  • Apr 13, 2011
That looks like a great project.
Definitely attack the rust first. Then the suspension and brakes. A Granada or a Maverick is a good donor for front disc brakes on the cheap. Just make sure the donor car has 11" rotors.
Those two things should keep you busy for a while.
A
alextank8
#10
  • Apr 13, 2011
  • #10
what all do i need to buy if i redo the brakes, like a whole rear and front disc brake kit or something?
P
Pony66
124
#11
  • Apr 13, 2011
  • #11
That is sweet if you have disc brakes. Most old Mustangs had drum brakes. What year is yours? For drum brakes a rebuild could mean new wheel cylinders, brake shoes, have the drums turned, new flexible brake lines for each wheel and a hardware kit with springs and stuff. If you have a 65-66 I would put a dual chamber Master Cylinder on it.
mustangmutt
339
El Paso, TX
Apr 13, 2011
#12
  • Apr 13, 2011
  • #12
Call around to your local salvage yards and ask if they have any Granadas that still have the front disc brakes. If you find one get the spindles and proportioning valve. If the Rotors are good get them too. Although new rotors, calipers and bearings are not expensive. You will also need to get Granada outer tie rods. If your car has factory Power Steering the drivers one won't work but you can get an adapter bushing from Mustangsteve.com.
On the Rear it is easy to adapt mid to late 90's Crown Vic rear discs. I think there is a thread on this swap here on the Forum.
The stock rear drum set up is adequate for a daily driver, but front discs make a big difference. Especially when you drive in the rain. Use a Master cylinder for a Maverick with Manual Disc brakes. I have done this to a few cars. All showed a major improvement over the stock Drum Drum set up. For some reason one of them worked exceptionally well, you would think it has Power brakes.
There are also people on ebay that sell complete packages for the Granada upgrade, but its funner to scrounge around a Junk yard.
robbz28
775
Epps, LA
Apr 13, 2011
#13
  • Apr 13, 2011
  • #13
My car had front drums and I managed to find a conversion online that converted some late model chevy calipers to mustang and it was a complete power swap kit, with the master cyl, prop valve, new pedal, rotors, everything and it cost me 650....it's nothing original, but it works great...much much better than those spongey old drums. If you are interested I can probably find more info about it.
A
alextank8
#14
  • Apr 13, 2011
  • #14
mine is a 65 as well
A
alextank8
#15
  • Apr 13, 2011
  • #15
ya im interested thanks. i really dont know much about the brake system as i do other stuff so anything will help
A
alextank8
#16
  • Apr 13, 2011
  • #16
about how much do you think a new granada kit would cost me both front and rear
robbz28
775
Epps, LA
Apr 14, 2011
#17
  • Apr 14, 2011
  • #17
Theres a front brake swap on fleabay for 550...no power booster or master cylinder tho, so after you add those items that will put you about 750. There is that kit that I mentioned earlier on there as well for 650. You might can piece you a granada swap together, but if your junk yards are like ours, they dont have anything older than mid 90's.
mustangmutt
339
El Paso, TX
Apr 14, 2011
#18
  • Apr 14, 2011
  • #18
Brows ebay for disc conversion kits. The Granada is only for the front, but there are many choices for the rear.
Hack
1,945
Minneapolis
Apr 14, 2011
#19
  • Apr 14, 2011
  • #19
There's really no need to do rear discs. If you're on a budget most of your stopping is in the front anyway. Leave the rear drums and just do discs in the front and your car will work a lot better. Mustang Steve has some very good budget options too. I'd rather put Ford parts in my Mustang than Chivy. Just me.
A
alextank8
#20
  • Apr 14, 2011
  • #20
ya i agree i want to keep as many ford parts as i can on it
1 of 2 Next Last
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
I don know what im doing!
  • Sha_lala_pookie
  • May 5, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 11, 2025
Sha_lala_pookie
