First off, how do you know the numbers on your car? Did it really crank out an even 300 hp/400ft lbs? If it did, and you spent the dyno time getting your jetting and timing right, and you're sure that what you have is spot on, fine, but if you're using desktop dyno or some other power "estimater" then you need to stop using that start doing some testing. You don't really need a dyno, you can get fairly close by using any one of the accelerometers that are available. I've used a G-Tech Pro with very good results, it really helps fine tune both your car and your driving. You didn't mention what gear ratio and what tire you're running, nor did you mention what you have already run in the 1/4. You say your car is a 12-something, is that 12.99 or 12.01? There's a huge stretch of time in between the two, and thousands of dollars so just how close are you now?
