I have a Cobra intake Upepr and Lower, and all the gaskets...but thats it. I already have a 65 mm TB and such, but am wondering If I need anything esle to bolt this sucker on the car. I'd like to get it put back together soon! Thanks
everything should just carry over since it is a direct ford replacement intake made for a 5.0. Since you are down there i would put on some new RR's and a 1/2 inch or so intake spacer.
do you have the right bolts. two of them will fit from your stock intake...but two others have to be 6 1/2 inch and two others will have to be 7 inch. but if you get the spacer it comes with 7 1/2 inch bolts and you will still need to get 7 inch bolts.
umm be be careful not to shift ur lower gaskets, or itll be a pain in the ass to take it apart to replace it again, other then that make sure u have the rigth bolts like ECU5.0 said
Thanks guys! I have a 1" trickflow spacer for a GT40 and all the bolts and everything. Am I right in that if my lower gasket set is cork front and rear, to not use it and use a 1/4" bead of High temp silicon?
I have the red high temp RTV is that ok to use on that?
