What do I NEEEEED?
Mustangmekanic2
MA
I have a basically stock '94 GT. Its got a Magnaflow after-cat, and an MGW shifter. What do I need to get to 310-325 rwhp on a naturally aspirated engine? im going to be spraying a 100 shot, so what do i need to get to 425 rwhp with a 100 shot? Im up for anything but digging into the engine. I can do heads/cam/intake and other bolt-ons. Is there anything you guys can suggest?:shrug:
typically any aftermarket h/c/i swaps you net anywhere from 290 - 320 rwhp depending on brand, and supporting mods...a trick flow top end kit or a afr 165's/ performer rpm intake/ custom cam are two different popular combos people choose for there 5.0, either one will put u at the 300 rwhp or more.
What is your budget?
Here is what I would do for 320-340 RWHP:
- AFR 185's with upgraded valve springs/ARP 7/16" studs
- Holley Systemax
- FTI Custom Cam (or similar)
- 10:1-10.5:1 Compression
- 24 or 30 lb Injectors
- Matching 80mm MAF
- 70mm Throttle Body
- 1 5/8" Longtubes
- 6,200-6,500 RPM
With the right set-up and tune, you can make that combination work:nice:
The RWHP will go up, the more aggressive you want to go.
To reach 325 NA rwhp with an OEM block is no small feat :Word:
You can't compromise on A N Y parts with a goal such as this :nono:
Dizzy twisting & elevated fuel pressure is not gonna cut it for tuning :nono:
Here are my thoughts :D
First of all ... your motor needs to be fairly fresh
or
At least be proven to have good ring seal for maximum efficiency
These are general recommendations for main combo parts :)
1) TFS or AFR heads with 1.6 RR's
2) Ported mid length runner intake such as Edel RPM or TFS Track Heat
3) Custom cam & ensure your guy knows 325rwhp is expected
4) Larger tb & maf
5) 30lb inj's
6) 255lph pump
7) LT's & OR pipe
8) Pulleys
9) Custom Tune
You'll want to get your compression up with tactics such as ...
Small chamber head choice
Cut the heads a bit
Thin head gaskets
Be prepared for a good bit of cam lope :crazy:
and
Its gonna be pretty thirsty for 93 grade around town :rlaugh:
That should put you in the ball park for your goal :D
however
If your cam guy tells you something different :shrug:
Listen and obey him ;)
and
Forget what I said :rlaugh:
Grady
Also keep in mind, the less accessories your engine is turning, the more output it will make:nice:
However, I like my belt-driven accessories: Air conditioning and power steering for example:nice:
