What do you think of these mods?
Can I run bigger injectors with the TB, Plenum, filter and SCT mod? Or are bigger injectors only for FI? I am not talking about monsters just something a little over stock, I still have to pass cali's emissions test too.
Also deftsound, what about the professional products bigger fuel rails? If I don't do injects are those a worthy 75 bucks for my mods?
No there is no reason to run bigger injectors or fuel rails unless you are FI or have some serious mods. Once you hit the 300rwhp mark, then people start thinking about bigger injectors, plus your car can't take advantage of the bigger injectors unless it is specifically tuned to do so.
As far as fuel rails, the stock ones are good to over 5 or 600rwhp i believe, no reason at all to upgrade unless of course your car is pushing that kind of power.
I have all the N/A bolt ons. I would say the only thing I regret getting was the K&N CAI. Make your own CAI. Remove your stock filter, buy a K&N drop in and remove the air silencer. As far at T/Bs go I would get the BBK 78mm tb/plenum combo. Also I noticed a difference right off the bat with an aluminum drive shaft and its not like they are that expensive.
man im tempted to try an aluminum driveshaft...i guess im just a little skeptical for 250$...
Blower is definitely the way to go, except you need to be concerned about you internals. If you are going to go with these bolt on’s, I would go with the JLT True CAI (fender well), Accufab 75mm T/B combo. Everyone is going to tell you that it is a waste of money N/A, but you have to start somewhere. The T/B will give you better throttle response. Under drive pulleys are good stay away from the piggy backs (March or Steeda). I would definitely go with long tube headers and full exhaust, Kooks if you can afford them, definitely not BBK. You will get good gains with full exhaust. To do that you need a tuner, Xcal 3 is what I have. With gears you should go with a short throw shifter (MGW), gears will weak you car up nicely. When you mod your car with these few item it is safe to have it custom dyno tuned. With no bolt on you can gain as much as 20+ rwhp from just a custom tune. I have a few items for your 2V motor you might be interested in. See link below.
http://www.stangnet.com/mustang-forums/804498-96-04-gt-performance-parts-nib.html
Whats wrong with BBK? I love my BBK longtube headers and midpipe. Plenty of people run BBK and like them.
I think BBK makes great quality parts...
As far as shifters its a matter of preference. MGW makes nice shifters, I have an MGW and like it but lots of people prefer the Steeda Tri-ax. Infact, I have run the cheap short shifters off american muscle and think they are a great product....
20rwhp from a custom tune on a stock car? Sorry but I call BS there, show me the dyno sheet...most people gain 10rwhp at the max on a nearly stock car...
I got the K & N drop in filter and installed it today. Made a little difference in throttle response and pulled a little harder. But back to TB/plenums. I know its more money than the professional products, but I kinda like the BBK integrated TB/Plenum. Will my stock air tube fit over this and is it OK to run a 78mm on a stock computer?
Thanks
Thanks
As far as shifter preference go's I have had Steeda Tri Ax shifters on both
of my mustangs and really like the feel of this shifter alot.
The Professional Products stuff is the cheap stinky pile.In the
past I know people have had problems with their throttle bodies
sticking open on them and the springs are obviously really weak.
All the Professional Products stuff is made overseas in a sweat shop where
workers are forced to work slave labor for low wages working long works probably under poor conditions.
Well the stock intake tube barely fits over a 75mm throttle body opening
and it's a tight fit.I recommend not going with the BBK integrated throttle
body and plenum on N/A cars as you will lose low end torque from that
massive throttle body opening on N/A mustangs.On forced induction vehicles
this would be a better mod I think.I know a 70mm or 75mm throttle body is
more than efficient on a N/A mustang.
Iceman, its not a turbo set, a large throttle body setup is not like a large turbo or something. Plus 3mm is not a huge difference over 75mm. I just want to know if it will fit over the stock intake tube.
Well since the stock intake tube just barely fits over a 75mm throttle
body and is a tight fit I would say it wouldn't fit and you would have
to get a aftermarket CAI tube for it to fit properly.
Definetly go with the stinger catback...and then the gears...gears made all the different in the world...probably the best results in my opinion..and see about a street tune once you have your gears in since your speedo will be off and you will be racking on more milage than you are actually putting on.
MidnightDriver - if I may make a suggestion, go with upgrades that you can build upon. Power Adders Heads, Cam, Intake Manifold, gears, headers and tunes are the real performers.
Most bolt-ons are offer nothing on stock engines but bling and bragging. Despite what many people say, the 2V 4.6 has a lot of really good engineering in it and two areas where there is no significant improvement to be had at stock levels are the entire intake tract and downstream of the exhaust crossover. Nickel and dime bolt-ons are doing nothing but nickel and dime-ing you and giving little in the way of performance. Until you are making serious power, they are mostly a waste of time and an even larger waste of money. Remember, every manufacturer is trying to sell you something. No matter what they sell, or how good or bad their product is, they need your money to continue their business. There are companies out there that tell outright lies and manipulate data to their benefit to ensure they get your money....they have certainly received a lot of mine. Please beware. I offer below a list of things that have worked, and not so worked. These are my opinions. I am not trying to offend anyone.
The little stuff - very little offered in stock applications, everything combined will not add up to even one of the items listed on the GOOD stuff.
CAI - can actually throw off your tune, causing loss of fuel economy and improper metering by causing noise in the MAF signal. Up to about 350 hp it is not going to be a significant restriction. Any performance gain you see can probably be attributed to the product screwing up the metering of the air resulting in a lean condition.
Throttle body - will give you seat of the pants feel. Everybody says I can feel it all though the pedal. That is because it is physically allowing more air for a given pedal position. It is not an restriction compared to other parts of your engine at stock levels. In fact most people see a reduction in peak torque. The stock 70mm is not going to be a significant restriction until you get within 10% of it's max flow, which is roughly 475CFM. The same applies to the entire intake tract.
Ignition - until you get a supercharger or are spinning past 7500 rpm, you will probably not see any real gain either in coil packs, COP's or control boxes.
Hi Flow air filter - get it if you want but don't expect it to give you much of anything initially. Past 300hp it starts to pay off for the purchase price.
MAF - not a restriction as it is physially larger than the TB, which is also not a restriction at stock levels. Do not get one until you actually are maxing out the stock meter. you will max out the meter voltage long before it becomes a physical restriction.
Mufflers - get a set you like the sound of, beyond that....well thats really about it until 400hp
Now the good stuff....
Power Adders - Superchargers, turbo chargers, and nitrous all offer great dollar to horsepower value...the downside is there is a large minimum to buy. Systems are pricey, but oh so worth the price. Power adders offer offer no real reduction in overall physical air restrictions, but either mechanically or chemically increase the amount of O2 entering the engine. Having a built bottom end will cost a lot but will give you longevity at higher than kit boost levels.
Heads - Single largest restriction in your engine. Get a set of Trick Flows, ported PI, or ported SVO's. The Trick flows offer about a 100hp increase. The others can add a significant level of power as well. A good set of heads will make the most of every other part you put on your car.
Cams - A good set of stage 2 cams will give you between 45 and 60 peak hp with even more for any given rpm after the power peak. A stage one set can improve performance throughout the RPM range on a stock car. A radical set can be the crowning piece of a fire-breathing monster.
Gears - They don't actually give you power but they change the overall torque multiplication of your engine in every gear and put into your powerband faster. At $150-250, nothing, and I mean nothing, will match the bang for the buy-in of a set of gears. On the downside, aggressive sets can cost you a little fuel economy.
Exhaust - Tuned Length Long tubes only, shorties get you virtually nothing. The exhaust manifold is not a physical flow restriction in most cases, the additional power and torque comes from effective exhaust scavenging. Some mid length sets achieve promote some scavenging.
Intake manifold - An upper plenum will get 10-12hp and is a decent dollar to hp purchase. I used to use Accufab but any are an improvement over stock. An entire manifold will give you better high rpm power. The pi stocker is actually pretty good and until you are forced aspiration, it only loses out past 6k to a couple of others. typhoon and the dorman (an OE replacement)are complete junk. Obviously the Bullit and SVO are an improvement, as is the Trick flow which is actually based on them and offers matched runners. Despite a lot of hear-say, the P-51 is a good choice for applications that it is specifically designed for. Despite the genuine gains you will see, naturally aspirated, the price of a complete manifold does not justify the power you get. Until you are doing a max NA effort or have a power adder (especially nitrous since most are aluminum), your money is better spent elsewhere.
Hopefully this information can help you make the most of the resources you have available. I hope I don't offend anyone, that is certainly not my intention. I only offer these opinions out of my own experience, based on mistakes myself or my friends have made.
I agree with everything above except two things:
1) You are not going to get a 100hp increase with a set of aftermarket heads unless you are running FI or nitrous. Most poeple, with ported heads on an N/A car see gains of 30-40rwhp....On a F/I car, you may see 100rwhp but even that is a stretch...
2) You are not going to see an increase of 10-12rwhp with an aftermarket upper plenum. Now, matched with an aftermarket TB you may see 10-12hp, but Not rwhp unless of course you are FI. Most people on N/A cars see between 3-5rwhp gain with an aftermarket plenum...and thats being generous...
What are the miles on your car, I'm just hitting 98,000 and wished I had spent the money on some preventitive maintenence, you know like the sensors that go bad right at 100,000 miles, maybe some gear oil, transmission fluid, ball joints, seals and gaskets!? Lets face it, the bolt ons are usally just going to improve engine drivability w/ minimum horspower, the CAI is just a fad, really for looks. Unless this is going to be a drag car or you going FI. Only w/ FI are going to see full use of your bolt ons. I guess w/ out going on and on, just save for FI or start replacing the parts if your mileage is high!
