What does it mean when a vehicle blows out blue smoke on every startup?
Thanks guys. It is definitely blue. Puffs out like somebody smokin a pipe on startup and then instantly stops. Strange thing is that the car only has 45k on it..
Should I do something about it?
Above-thoughts sound good. Gravity allows a tiny bit of oil past the seals when the car sits overnight and this burns upon start-up.
You can do a leakdown test if you desire - that helps narrow down where the issue is comin from (it could just by one valve that's doing it).
:OT: GMGT, have you smoked turbos very often? I had the fun of going through several rebuilds. I was AMAZED at how just a couple of drops of oil (passing the dynamic shaft seal) could make SO much smoke.
my cheby V6 did this every day and ran strong till 150k miles when I sold it, and I am sure it's still going to this day. Valve guides, again.
You can yank the plugs and see which cylinder is the culprit and r/r the seals on that head but IMO it's not worth it. JUst change the plug every year and you should be fine.
Scott
Every chevy I have ever owned has done this at one time or another. Both of my Z28's did it eventually. Changed the valve seals and it fixed it. However my 4.3 s10 needed valve guides so seals didn't fix it.
I would say its probably just your seals.
What kind of oil do you use?? A friend of mine bought a new Nissan Maxima. When she brought it in for service, she asked the tech to put in synthetic oil. He said that the valve seals in the nissan engines won't last as long if you use synthetic oil.:shrug:
I checked up on it with a couple of other dealers and they said it was true. I also asked at the local oil change franchise, the guy said that the franchise will not allow them to use synthetic in nissan products.
Since nissan makes infinite, I would think it's the same??
Vic
I have this problem on my Mustang, small puffs of blue smoke under hard acceleration.
Watch this vid at around 2.22
http://www.youtube.com/watch?v=7z6tSzCfSq4
You see a little blue cloud coming out of my Mustang :nonono:
Just for total clarity for future searchers, it should be explicitly noted that smoke under acceleration is very much different than Pokageek's smoke upon start-up.
no these turbos ive bought used and who knows, probably have 200k on them for all i know. They are just starting to leak a bit past the seals. I've been trying to get around to rebuilding them
