What else do I need to get when I order my gear?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
I have seen installation kits, and master bearing kits. Do I need this and what comes in the Installation kit? Here is a link to the ones I was looking at. http://www.mustangtuning.com/fopege3ra1.html
EDIT: and what about the Motive gears? Are they any good? They cost a lot less and the car is basically stock and will stay like that for a while. So would it be fine to go with the motive gears and upgrade to the Ford Racing when I get out of school and actually start doing stuff to the car?http://www.mustangtuning.com/motive-373-gears-ring-and-pinion.html
you need, gear,master bearing kit(which contains differential pan gasket,bearings & races, Shim Kit, pinion seal, pinion nut, crush sleeve, ring gear bolts and checking compound w/brush). , 2 axle seals and bearings(these are not included in the master bearing kit).,1 traction lok rebuild kit which contains the friction modifier.,4 pints of of hyphoid gear lubricant sae 80 or 90.,speedo gear(to correct your speedometer).
click on link below and read the thread it should tell you everything you need to know.
http://forums.stangnet.com/showthread.php?t=618253&highlight=gear+install
i bought my ford gears off e-bay 3.73 gears removed from an explorer for $40 thats one heck of a deal they looked and run like brand new there are alot of people on stangnet that have installed used gears and one post i read one member thought it was foolish to pay $150-$200 for a set of gears when you can get a set for under $60 that will work just as goodas new, i stand by his quote and fully agree i will run a search and post some gears for you to look at.
