what exactly all do i need for a t-5 swap?
Check Stinger's site, ebay, and your local junkyard to see what you can expect to pay. Here's the breakdown of what my swap cost:
Total Cost of Transmission Swap:
Pedal Assembly: $15
Shifter: $10
Bellhousing: $10
Flywheel: $10
Shift Knob: $10
Shift Boot/Bezel: $10
Driveshaft: $25
Crossmember: $15
Clutch kit: $60
Pedal Assembly Sale: -$45
Resurface: $25
Clutch Fork: $7
Clutch Cable: $10
Tranny: $100
Tranny Mount: $30
Don't forget to get an adjustable quadrant and FWA while you're in there.
Ash
Crovax said:
a t-5 that has no overdrive. :(
Easy fix. Pull the tailhousing and the 5th gear parts are right there. No need to get into the main part of the trans. All you need is a punch to drive out the roll pin and a pair of snap ring pliers and you can either repair the synchro or replace the gears
Or you might need to replace the 5-R lever :shrug:
