What first?? Springs and Shocks or Anti-Roll Kit?
  • Thread starter Thread starter GermanyBert
  • Start date Start date Oct 30, 2008
GermanyBert
Germany
Oct 30, 2008
  • Oct 30, 2008
Need a little help from the guys and gals in the know.
I don't have the funds to do all my planned suspension upgrades at one times so I will be doing it in two phases.
Shocks and Springs at one time and anti-roll kit at another.
I plan to go with Eibach Pro-Kit Springs with Tokico D-Spec shocks front and back.
I am going with Eibach Anti-Roll kit.
Question is since I am doing this in two phases should I go with shocks and prings first or the anti-roll kit...or does it even matter?
Lastly....will I need a realignment after each phase?
J
Justin01
546
Texas
Oct 30, 2008
  • Oct 30, 2008
I think most people go shocks and springs first. Maybe check out a pair of upper strut mounts (CC Plates). I know steeda has some pricey ones but I think you can get a pair for the gt500 for much less. I know you'll want an alignment after the drop. You shouldn't need it after the roll bars though.
NastyStang113
1,567
Florida
Oct 30, 2008
  • Oct 30, 2008
Springs and shocks ... The alignment will only needed to be done after this.
GermanyBert
Germany
Oct 31, 2008
  • Oct 31, 2008
Thanks for the info.
walter
1,054
Houston TX
Oct 31, 2008
  • Oct 31, 2008
I wouldn't rule out an anti roll bar kit out as the first mod as it allows you to use what you already have there more efficiently. It is also definitely a more cost effective mod as well compared to the spring/shock replacement.
Who knows if looks aren't everything to you you may just find out that that's all the suspension you really need. If you do go this route I would definitely also consider getting a set of lower control arms.
Remember suspension components work best when they are FIRMLY planted on the ground. The sway bars will take care of that during the turns, the control arms will help during accel/decel.
GermanyBert
Germany
Oct 31, 2008
  • Oct 31, 2008
That makes a lot of sense.
I want to avoid uninstalling and reinstalling parts. Can I install the Anti-sway kit and control arms without touching the shocks/springs and visa-versa?
garbledwords
44
Nothern VA
Oct 31, 2008
  • Oct 31, 2008
Yes, those are two seperate installations.
GermanyBert
Germany
Nov 4, 2008
  • Nov 4, 2008
Thanks everyone for their advice and opinions.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
P
Fox 17" Deep Dish Bullitts on Rear of Fox, 275/40/17?
  • pindude80
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2025
