what fuel pressure?
5literstang
1,374
Clark, NJ
what fuel pressure should i be running? my mods are dss pro bullet shortblock, trick flow twisted wedge heads, track heat intake, trick flow stage 2 cam, bbk long tubes, catted h, compression ratio is 8:5:1 right now i have it set at 39 at idle and 45 wot, any help would be appricated. thanks!
your going to need
bigger injectors.
New Maf caled for injector size.
Get the car Tuned.
AKA $$$$
If you still have the stock fuel system you may be able to band-aid it by upping your fuel pressure but without a A/F meter or logger its hard to say what to set it at.
You'll probably need to get it on the dyno or get a wideband to see where you are at, it's hard to say what your AFR is.
Shoot for 12.8-13.0:1 and 32-36* total spark for good power at WOT.
A custom tune is going to really help you get the most out of the car at all throttle positions and make it drive like stock again.
Wes
