What fuel rails
Pops Fun
961
14
59
Cincinnati, Ohio
Hi
Stepping up for a little more power, at 507rwhp and could get 3 to 6 more #'s of boost...... smaller pulley on the vortech. :)
Going to put 60# injectors and fuel rails on my 94, was wondering what brand/type of fuel rails to get, already have the injectors.
I've heard there could be problems with hitting the distributor ?? Next year maybe water/meth, and maybe fuel line upgrade??. That is why I am installing the bigger injectors for growth.
i have some rails in my garage that i got a while ago and never used. if you're interested in them, let me know and we'll figure out what works for us both. i don't know about the distributor issue or if these exhibit or avoid it.
If you don't want to change your fuel rails and distributer, you can dual feed your stock rail. Little ricer trick I learned when I had my MR2. You can double the capacity of your stock fuel rail by welding another fitting on the other side, or T into the flex line.
Kurt
To me with the stock dist the only choice is Behind Bars Race Cars rails. Your going to have to do the whole fuel system over though because the lines are also holding you back. Most fuel rails like the mallory you linked to cause the drivers side front cylinders to go lean because of where the return is placed.
Fuel rails mustang BBRC clear the distributor
Im with him ...I love my BBRC rails, top notch stuff and they clear the stock dizzy no other rail I know of will clear the stock dizzy.
Hi
You are correct I need the whole fuel system from the pump to the fuel bars as well as the fuel bars. I taking it a part at a time, this year bigger injectors 60#'s and fuel rails, next year the lines from the fuel pump to the fuel bars.
Considering the BBRC bar, it comes out a lot further, guess it doesn't hit anything and the crossover just goes in front of the distributor.
Pictures of how yours is setup??
Steve
