What intake for this combo, please help
  • Thread starter Thread starter 68converted
  • Start date Start date Jan 20, 2004
68converted
772
Colorado
Jan 20, 2004
  • Jan 20, 2004
Ok, I have a couple of choices: Holley Systemax heads 1.94/1.60 (most likely choice) or the AFR165's with either the E303 or the one I think I want, the Xtreme Energy XE264HR. Based on the heads and cams, what is the best intake for me? I will have a FR 65MM TB and 70MM MAS. I want low end torque with good Highway response with my AOD and 3.55. Advice.
H
Highbredcloud
1,075
Palos Hills, IL
Jan 20, 2004
  • Jan 20, 2004
Well if you want low end torque GT-40 style intakes are great...However, with heads such as the AFR's or Holley's you'd probably be better off with a performer intake and a nice custom cam to compansate for the low end TQ.
5.0 HOtrain
2,247
New Hampshire
Jan 20, 2004
  • Jan 20, 2004
Go for the performer, or even the cobra would work fine for you. How about the tfs stageI cam with the afr's and the cobra intake. Or go for a custom cam with a ported cobra intake. Wayyyyyyyyyyyy to many options. Good luck.
mike.
68converted
772
Colorado
Jan 20, 2004
  • Jan 20, 2004
Ok, two say performer. Is that the Performer 5.0, Performer RPM or the new Performer RPM2? If I did the Cobra would I have to have the bottom port matched?
mike keirstead
1,121
ROLLING A JOINT
Jan 20, 2004
  • Jan 20, 2004
I would get the AFR 165...the XE 264 cam...and either a HOLLEY systemax intake or a performer RPM. Also I would get 3.73s with that AOD.
5.0 HOtrain
2,247
New Hampshire
Jan 21, 2004
  • Jan 21, 2004
If you're going to go with the performer rpm, get the new rpmII.
maverick0716
3,924
Chilliwack, BC, Canada
Jan 21, 2004
  • Jan 21, 2004
What are the specs on that XE264HR cam?
Jason 302
685
71
68
Newark, Ohio
Jan 21, 2004
  • Jan 21, 2004
Well, I agree with these guys except they seemed to miss the part where you say you want good low end torque. The RPM or RPM 2 are not the best choices if that's what you're looking for, but probably the best for AFR's otherwise. So I say the Cobra or for a few extra plus (don't know if you have it already with that 65mm TB) an EGR spacer (Cobra you don't need one, already built into intake) the regular Edelbrock Performer. I don't know much about the Holley intake but remember, it was designed to run with those heads.
5.0 HOtrain
2,247
New Hampshire
Jan 25, 2004
  • Jan 25, 2004
mike.
Pretty sure the cobra was mentioned in there
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Fuel 19lbs EV6 fuel injectors, what fuel pressure???
  • PonyGTrider
  • Jul 11, 2024
  • 6 7 8
13K
Fox 5.0 Mustang Tech Jul 25, 2024
PonyGTrider
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
