What intake??
  • Thread starter Thread starter jstang209
  • Start date Start date Aug 31, 2005
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 31, 2005
  • Aug 31, 2005
what intake would be good with brand new stock heads/cam? i plan to upgrade the heads/cam but later tho.. im just asking because i heard a good intake with stock heads would just hurt performace right? or did i hear wrong?
87MustangGT5.0
153
Maryland
Aug 31, 2005
  • Aug 31, 2005
I would think a Trickflow intake even with the stock heads would really do your car some good. Then down the road when you replace the heads and cam, they will be better mods because you already did the intake. You probably need more advice from somebody that actually has fuel injection lol.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 31, 2005
  • Aug 31, 2005
yea i was thinkin about gettin the street heat and maybe a 65mm tb
N
NUTCASE
187
  • Aug 31, 2005
I (as always) suggest the e-brock preformer
very good runner out of the box, works well with stock components, leaves enough room for heads/cam mods, they can be ported, and they got this new design out where you don't have to fight with that god forsaken center bolt for like 20min
87MustangGT5.0
153
Maryland
Aug 31, 2005
  • Aug 31, 2005
So what do the majority of you guys like, the Edelbrock or the Trickflow? I notice most either have one or the other.
87MustangGT5.0
153
Maryland
Aug 31, 2005
  • Aug 31, 2005
The Holley systemax seems to be popular too, I think I read that it outperforms them all out of the box???
1990LXDropTop
430
Western Massachusetts
Aug 31, 2005
  • Aug 31, 2005
I like my edelbrock performer intake. Very easy to install and flows great. I do have heads/cam as well, but I have heard the performer is the way to go with stock heads. Either that or a cobra intake. The street heat would work well too, but some say its a bit overkill for stock heads.
N
NUTCASE
187
  • Aug 31, 2005
unless you plan on keeping it stock internal I think the cobra is a waste. why pay $400 for a manifold, then get a $400 port job when you could of gotten a $400 something else first time around and been done with it.
I just don't support the trick flow becouse I have had to many friends get them and make no low end torq out of them. I knew a guy with an intercooled prochargen notch that ran really good with the tfs but is car diddn't weigh alot and he was running some pretty high boost
Sicarius428
2,085
Aug 31, 2005
  • Aug 31, 2005
Edelbrock intake and a 70mm TB should start you in the right direction. The street heat is a really nice intake but unless you got the heads to take advantage of it... low end torque will suffer.
Kevin
vikingpower
656
CWU Ellensburg, WA
Aug 31, 2005
#10
  • Aug 31, 2005
  • #10
aint that the truth! Cobra intakes are a thing of the past like the B303 cam, there's better stuff out there now
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 31, 2005
#11
  • Aug 31, 2005
  • #11
heh thanks for the inputs.. i think i will go with the edlebrok performer and a tb
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 31, 2005
#12
  • Aug 31, 2005
  • #12
Man, I can prove you wrong in SO many ways - you need to spend some time at my site, especially in the dyno section of the photos.
I would suggest a good used Cobra/Explorer or Performer above all others.
But what do I know......................
DW5.0L
172
Florida
Aug 31, 2005
#13
  • Aug 31, 2005
  • #13
I was in the same position and decided on the Performer 5.0 and an Accufab 70mm tb-egr. Mustang Warehouse has the tb for $265.94 shipped.
1990LXDropTop
430
Aug 31, 2005
#14
  • Aug 31, 2005
  • #14
Before my H/I/C swap I had an explorer intake. I got it for $200 off the corral. At the time I was very happy with it. I felt a very noticable SOTP increase when ran with stock heads/cam. I ended up selling it because I wanted the Performer intake for the looks and to match my heads better. IMO you can't go wrong with a cobra or explorer intake. Look for a used one. The GT-40 is good too but is too much $$ for what it is.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
