what is an output sensor circuit malfunction?
I had Advance Auto do one of those "free scans" today because my 1999 GT has been stalling when I come to a stop with the clutch in. The idle will wander between 800 and 200rpm then die. But this only happens when the car is moving.
Here are the codes I got: (written exactly as the print out has them)
DTC (codes)
P0125
closed loop fuel control
insufficient
coolant temp
DTC Pending (codes)
P0356
ignition coil F
primary/secondary
circuit malfunction
P0720
output speed sensor
circuit malfunction
The car had a misfire due to water in a plug hole. I have since replaced all coils and the misfire is gone. Also, the car was driven with the thermostat removed for about a month. Both were done before the scan.
If i have a speed sensor problem, how is the speedometer still working?
Also, what is the difference between "DTC" and "DTC pending"
Any ideas?
DTC (codes)
P0125
insufficient
coolant temp
DTC Pending (codes)
P0356
ignition coil F
primary/secondary
circuit malfunction
P0720
output speed sensor
circuit malfunction
Any ideas?
