Green&GoldGT
I don't think anyone has answered his question.
The romeo engines have bolted on cam gears so i think u can re-use those or buy new ones. When u bolt on cam gears to aftermarket cams u use 2 CRANKshaft bolts. Other than that you will need valve cover gaskets. But you will need other things if u install them yourself like the cam rentention tool and lube b4 u put the cams in, not to mention coolant or oil if u take everything apart.
Not only do cams give u added horsepower but u up your shift points which helps alot especially if u have gears. I highly suggest a tune.
