I'm exploring the possibility of making a set of negative wedge plates out of stainless, but I don't have a set to get dimensions from. Does anyone have an uninstalled set they could some dimension off of for me?
I made a set for my '70 on a bridgeport out of 6061 aluminum, and I made them 18 degrees. I don't know what Pro motorsports does. I did a 2 inch UCA drop and I figured that 18 degrees covered that approximate angle change for the '70 UCA length. It depends on how much you move the UCA mounting point how much angle you want....
I really wanted to do the Opentracker style modification to my control arms - that is, cut a wedge from the UCAs, bend and reweld them with reinforcements to the proper angle......
I made a set of wedges, even made angled washers so the bolts wouldn't bend when I tightened the ball joint. You need a certain type of ball joint so the grease zerk is accessible IIRC.
I saw Opentrackers method and did away with the wedges.
Having done both, I'm not sure which would be more work to make, but I like the way the ball joint sits without the wedges.
I don't know if it's any lighter though, I boxed them while I was at it and welded the reinforcing plates on the area I cut and bent.
the arm in that photo has a roller bearing rather than the stock metal bushings, which required a new cross shaft. an elegant solution for replacing the metal bushings, but rather expensive.
Actually roller bearings are not very expensive. I expect the roller bearings cost less than $10. Retailers seem to want to charge a lot for them, though. The actual bar of stock that the bearings ride on shouldn't cost more than $50 in any kind of volume, but I would probably just make one.
Things of beauty I tell ya...
+1
Thanks for the help everyone. I'll have to land some old UCA before I try cutting and wlding them, but you never know. I bet most people take the brakes off of Granadas in JYs and not the suspension parts.![]()
