  • 1994 - 1995 Specific Tech
WHAT IS THIS???
  • Thread starter Thread starter armyed
  • Start date Start date Jun 28, 2007
armyed
36
Atlanta Ga.
Jun 28, 2007
  • Jun 28, 2007
Hey I just bought a 95 Gt and im wondering what this thing in the pic is thats not attached to anything. I have a feeling that its comes from the passenger side head with exhaust coming out of it then down to the middle of the H-Pipe because that also doesnt have anything attached to it and is blocked off. Also what is it used for and do I need to have it for emmisions. It has an offroad H-pipe on it but I have a Catted BBK one on the way. Any help would be awesome..thanks in advance.
C
chuck943
262
north carolina
Jun 28, 2007
  • Jun 28, 2007
a plugged off thermactor air tube
armyed
36
Atlanta Ga.
Jun 28, 2007
  • Jun 28, 2007
whats a thermactor air tube and where does it go and what does it do?
R
red95gtconvert
382
Ponca city, OK
Jun 28, 2007
  • Jun 28, 2007
It goes to the smog pump.
C
chuck943
262
north carolina
Jun 28, 2007
  • Jun 28, 2007
The Secondary Air Injection system is utilized in electronic control systems to divert secondary air either upstream to the exhaust manifold check valve or downstream to the rear section check valve and catalyst. The system will also dump secondary air to the atmosphere during some operating modes. It is used to help the catalytic convertors perform their function of burning excessive hydrocarbons.
vp6799
124
Massachusetts
Jun 28, 2007
  • Jun 28, 2007
That's part of the smog pump system.
armyed
36
Atlanta Ga.
Jun 28, 2007
  • Jun 28, 2007
so does any of this effect my emmisions testing or will it be fine and also does anyone have any idea where I can get a replacement so I can hook it all up. Any pics would be great too
Pokageek
2,767
MA, USA
Jun 28, 2007
  • Jun 28, 2007
Try an junk yard...if you really want to put it back on. These 94-95 put out LESS emissions than my v6 infinite AND 04 BMW btw. They don't need all of that emissions piping on it...depending on what state.
If I remember correctly, "factory" cats (meaning not aftermarket, require that air injection and can they not go bad by running the car with them on and no air injection?
HISSIN50
34
129
Jun 28, 2007
  • Jun 28, 2007
Yes.
Junkyard or resto houses. Half the same-era Fords out there use similar A.I.R. system components. You are probably missing the solenoids in the passenger fender well area as well.
Good luck.
EDIT: PG posted while I pecked. PG is right - the stock cats really do require the extra O2 to last as long as they can. Many newer cats free up some O2 during the reduction stage, hence not needing external O2.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jun 28, 2007
#10
  • Jun 28, 2007
  • #10
My question is ... does your car still have a smog pump? If you want to make it all emissions compliant, and it doesn't have one, you will need that as well. As far as I know, they have to be off a '94-'95 V8 Stang to work. Someone correct me if I am wrong.
I also agree with JT about the solenoids. If someone went as far as they did in those pics .. you more than likely are missing the AIR solenoids as well.
SN95StangMan
1,292
Lynwood, CA
Jun 29, 2007
#11
  • Jun 29, 2007
  • #11
Do you have an EGR as well?
It might just be the angle, but I dont see the tube in the pics...
armyed
36
Atlanta Ga.
Jun 29, 2007
#12
  • Jun 29, 2007
  • #12
Yes it has a smog pump and the egr is there it further up..well the seliniod is at least...I would have to take a look to make sure everything is hooked up right with it. Well I have a brand new BBK catted H-pipe coming to me in a couple days so I guess I dont need to worry about the thing being plugged. Thanks everyone for the info
armyed
36
Atlanta Ga.
Jun 29, 2007
#13
  • Jun 29, 2007
  • #13
I got it found an article about removing what it is if anyone wants to know it goes to the smog pump as well as the h-pipe..heres the link and thanks everyone for your help
http://www.allfordmustangs.com/techarticles/Smog2.pdf
gcomfx.com
3,690
Republic, MO
Jun 29, 2007
#14
  • Jun 29, 2007
  • #14
Those look like aftermarket headers. Do they have the bung for the EGR in them?
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
