What is Valve float
  • Thread starter Thread starter fidstang
  • Start date Start date Apr 3, 2006
fidstang
307
South Lansing
Apr 3, 2006
  • Apr 3, 2006
I have been hearing alot about valve float lately. It has got me thinking about my combo. I know what valve float is, I just don't know how to determine if I have it or not? Is it a sound? Is it the way it revs or lack of revving? I know it can be deadly to your valve to piston clearance because it actually keeps the valve open long which increases duration of the ramp. Please any info here would be appreciated.
2000xp8
SN Certified Technician
Aug 8, 2003
8,076
1,659
194
NJ
Apr 3, 2006
  • Apr 3, 2006
Basically your springs can't keep up with your cam. Sounds and feels like you are hitting the rev limiter, but you aren't.
You don't list your cam with your combo. If it's stock it's unlikely that you have a problem.
fidstang
307
South Lansing
Apr 3, 2006
  • Apr 3, 2006
It's a trickflow stage 1 and I have no idea what springs are on the stock heads. I guess it doesn't matter since I know I don't have valve float now. But, I will be going to ported gt40 irons off of my fathers 94 cobra. They only have 40,000 miles on them still, if their is a chance of valve float I will be upgrading the springs before the supercharger gos on.
2000xp8
Aug 8, 2003
8,076
1,659
194
NJ
Apr 3, 2006
  • Apr 3, 2006
With 1.7 rockers and a stage 1 cam, you should upgrade the springs before you put those gt40 heads on.
I'd also suggest that they be valve jobbed and bowls cleaned up. This way a machine shop sets the seat pressures on the springs.
Should cost around $200-$250 and is worth every dime, can get you up to around 15 rwhp. They will also check and make sure the rest of the heads parts are in good working order.
fidstang
307
South Lansing
Apr 3, 2006
  • Apr 3, 2006
Already have that planned. I am just doing a gasket match, minor and I say minor intake and exh port enlargement, sort side work, bowl blend and then I will be sending it to get a valve job. I will be upgrading the spring like you suggested just to be on the safe side. To bad the valve job, cleaning and guide replacement is going to set me back $350.
ExplodingGopher
517
The mistake on the lake (Ohio)
Apr 3, 2006
  • Apr 3, 2006
leave the intake port a little "rough" when porting. PORT & POLISH the exhaust port, every little bit help ford's piss poor flowing exhaust ports.
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
