WHAT IS YOUR MOTOR COMBO
91 HATCH
Banned
May 17, 2007
262
illinois
IM TRYING TO SEE WHAT MOST PEOPLE HAVE FOR A MOTOR COMBO PLEASE LIST WHAT YOU HAVE AND ANY DYNO NUMBERS IF YOU HAVE THEM
please no talking or arguing or asking questions it clutters up the thread thanx
This combo has been dynoed 3 times...
Currently: Honed stock bottem end, Stock E7s with GT40 valves, VJ, rockers, Cobra intake, 65mm TB, 75mm MAF, CAI, pulleys, LTs, X pipe, catback.
258/295
Last: Bone stock 100K bottem end, same mods as above, Prochamber, different catback.
265/308
Before: Same honed B/E, sam mods prochamber, and that different catback.
272/316
Somehow lost a ton of power (probably the 18" wheels, disc brakes, and wear and tear, but still ran 12.95 @ 106, and was trapping mid to high 107s last race)!
same dyno and do you remember the timing or was it consistent? My friend's turbo 240 made 288 hp, took it back the next week for a second run and for tuning at a diff shop and pre-tune it made 306, nothing else changed...
'88 stock bottom end, CI custom cam, Thumper ported E7's, Tmoss ported intake, 1.6 Scorpion RR, 24lb injectors, 65mm TB, 75mm MAF, BBK Shortys and xpipe, 4.10 gears.
270 whp/ 300 wtq
DD: 90 b.e. forged, p/p E7's, X Cam, Weiand X-Cellerator, 700dp, 150 shot, 4.30's
STREET CAR: 347 forged, Dart 210 cnc, Nitrous HP cam, Vic. Jr, 780dp, 3.73's
STREET CAR2: 4.6 forged, Patriot St.3's, Custom, Vic. Jr, 700dp, 76mm turbo, 3.31's
PS CAR: 310 forged, Anderson TFS, Anderson Custom, Stealth, carbed, very steep
Mods are in sig. Never been to a dyno, and don't plan to. Car trapped 103.7 in the 1/4 without tuning this fall; hoping to get it up into the 107-108 mph / 280 wheel hp range with help from a tweecer this winter.
Boss 302 block, 347 Forged rotation assembly
TFS CNC 205cc Track heat heads
Vortech Ysi-trim Cogged(22-25lbs)
Ported Systemax 2
90mm TB
95mm MAF meter
AFM high rev cam/springs
1.6 r.r's
Meth injection
Dyno #'s this summer/fall. Expected over 700rwhp
1969 windsor block, DSS 408 rotating assembly, AFR 205 heads, custom FTI cam, TFS Box R intake manifold, 90mm Throttle body, 42lb/hr injectors, 1 3/4 primary and 3" collector headers, 3" Mac Pro Chamber and 3" Mac Pro dumps.
306...Eddy small valve heads with some exhaust side grind time..XE270HR-12 comp cam, Typhoon (unported :)) and all the boltons....317HP/345TQ with a moderately agressive tune.
Graph in sig.
