What kind of times could one see with this combo....
5spd GT
"the 5.0 owns all"
9,516
Arkansas
A 93 LX 5.0...Automatic(rebuilt with a shift kit, trans cooler, stock stall :shrug: )
Thumper Heads, Custom Cam, 1.6 RR, Rebuilt Forged 306, Edelbrock Performer, 373's, 24lb injectors, 255lph fuel pump, DR's and all the extra supporting things that go along with a heads, cam, intake swap....Any ideas? Just curious....Thanks in Advance :nice:
David
I agree,I have a 93 lx,aod,not even close to all the mods you have made,but I'll tell ya what.I put a PI 2800 stall in and it made the car into a totally different beast! A better mod then my gear swap! ( 2.73's----3.73's)
So if I had a 2600 stall would it rev to 2600 or so and then move...or how does it work?
Times are still welcome for the above combo :D
Thanks again,
David
mike keirstead said:
You can hold your foot on the brake and rev it to 2600 and the car wont move...let your foot of the brake and VVVVVVRRRROOOOOOMMMM away you go!
If I rev it past 2600 rpm with the brake on the tires will spin right?....
also how would this affect daily driver...would it take more revving to get it to move from a stop for example:shrug:
Thanks again,
David
Ya they would start to break lose...if you had slicks you might get 2800 out of a 2600 and so on.
As far as daily driving you will love it. When you just driving normal it may lock up a little higher than normal but when you stomp on it it will flash up and lock and then go like a scared rabbit. Instead of locking up at 1400 it will lock at 2400-2600 or so. They are all different. But youd love it.
A 93 LX 5.0...Automatic(rebuilt with a shift kit, trans cooler, stock stall )
So what would I run with the above mods....and then
what would I run with the above mods with a 6-8 lbs of boost S trim :shrug:
Is High 11's possible or even mid 11's :shrug:
David
