lauras70mach1 said:Hobart handler 180.
Use the gas, flux core sucks.
LOVE mine.That is incorrect my Hobart 180 has a wider range than any 110 volt welders I have seen it will go lower as well as higher due to a better transformer. The voltage does not determine the welding ability of a welder it is the current and most 230 volt welders have a wider current range. When I was looking at a welder I searched all over for information and this is what I learned.0to100to0 said:i've done some welding but i've decided not to weld in my front and rear suspension systems from martz chassis. i think this kind of stuff is best left to a true professional, even though i do have some welding experience. i have found a lot of use out of a 110 machine, but i do wish i had one that ran on 220 as well. although, you kind of need both because you cannot weld sheet metal with a 220.
matt
Yah that is a great site I got a lot of good information and help from those guys.gjz30075 said:DJ, a lot of good reading over here:
http://www.hobartwelders.com/mboard/
If you are trying to weld tubing with more than 1/4" thick wall, I agree.0to100to0 said:i built a rotisserie for my mustang and i would not use a 110 machine for that thick tubing. you are simply not laying enough material down to make a good weld (when you weld tubing together you don't have the priviledge of welding from both sides.
Here we have NexAir, AirGas, Lindi and others and that allows me to shop around they will fill your tank for a couple of dollars more or exchange it. I like the fill because I have a new tank and it is unmarked keeping me out of the “I won’t fill my competitor” situation. And most of the exchange cylinders I have seen are with in a couple of years from the pressure check date. It also would allow me to move or get it filled somewhere that does not have that brand. We also have tractor supply that will exchange it as well. My plan is to keep it until it is close to needing pressure testing and exchange it. Remember if you are going to exchange a cylinder do it BEFORE the pressure check date some place will not exchange an out of date tank.1320stang said:At Airgas here in OKC, when you 'lease' the tank, they tell you you actually own it, your just swapping it out and the extra price is for having the cylinder pressure tested. I don't think it's legal to own your own tanks here anymore (not sure), and if you do (or did), you don't swap them out, you get your tank refilled as it's yours and they're not going to take the hickey getting your tank recertified, therefore it takes a lot longer to get it refilled. I only have two options, I think, here locally to get them refilled and the prices are about the same, Airgas is where I bought my Miller, and they're about 5 miles from my work.
I bought a big spool of wire (20#?) at Harbor Freight for $20 so I wouldn't have to mess with the 5# spools from Home Depot and Lowes.
Have you removed the lead and blown it out with compressed air the wire will leave wire dust as it passes thought and this needs to be blown out from time to time as part of regular maintenance. There are some pads that you can get that go between the spool and tensioning device that will help with this as well. As for rust I have not had a problem but I have found rusted wire in stores.1320stang said:I'm not sure what is wrong with ours, I think it may be where it comes out of the hard 'plug' where it goes into the front of the unit. But if I don't have the unit a bit away from whatever I'm welding on the wire won't feed. I think it comes from bringing the lead back around to the back of the unit and draping it over the regulator and back over the top of the unit.
1320stang said:Disagreeing information?!? You seem to confirm everything we've said. I agree there is nothing on a Mustang that you'll need a 220v welder for, but are you just buying it for the Mustang?
IMO, a single pass with a heavier duty welder is better than multiple passes with a lighter duty one. If nothing else, there's far less prep time, and if your doing it for $$$, time is $$$.
Another thing, you can't always get to the back side of 1/4" metal, example? Tube steel.
I want to build a car trailer as no one makes the trailer like I want it built. Am I going to use my Miller for the main frame? No, I'm going to use my arc welder. I'll use the MIG for smaller pieces and brackets and such, but the main frame will be arc welded. I'll be hauling a $30k+ race car on it and I want to be sure it's done right. But I also tend to over engineer everything, LOL!!!
As far as MIG machines go, Miller seems to be the prefered brand in most professional shops I've been in. Arc welder, it's about split. For a TIG, my chassis shop buddy has both and has tried others (L-Tec, etc.) and will go to the Lincoln every time. Most of the aircraft shops have Lincoln TIGs as well. Now there's a tip. These shops weld aluminum a lot and they tend to buy new machines every year as the high freq. "wears out". It's not bad after a year, but it is noticable between a year old machine and a new machine. For home use or light shop use, it'll probably last the rest of your life. Welding steel is no problem as your mot using high freq. If you think about it, aircraft mechanics make big $$$ and having a plane worked on is even bigger $$$. I think this is why they can justify buying new machines every year. I understand you can buy the year old ones for $1000-$1200 and they're pretty well optioned, but they just change out boxes and usually keep the cart with the tank and pump on it. So if your near someplace that has a lot of aircraft industry, you might try starting out there looking for a used unit.
MIG vs. TIG, for roll bars/cages, if it's mild steel, it has to be MIG welded but if it's chrome moly, it has to be TIG welded as per NHRA last I knew. You can change gas and the liner and weld aluminum with a MIG. Most people just get a spool gun and another bottle and go that route for aluminum.
1320stang said:Yeah, I think we're just saying, if you can afford a 230v unit, get it, if not, get a quality 135amp minimum 110v unit, don't skimp and get a cheap one. But if that's all you can afford.....
Look at you, you bought a 230v 175a unit, why didn't you get a 110v unit. You want to trade even up for my Miller 130 110v unit? I've got 4 heat ranges and infinite wire speed. IIRC, on a 230v unit you have infinite heat range as well, am I correct?
I got a 230V because it was recommended to me by a few people here and one of my buddies. Not knowing anythign about welders I took the advice of people and spent $300 more than I really needed to. Do I regret it??? No, but at the time the $300 could have been spent elsewhere. My buddy just to a little Lincoln 110v 130amp from Home depot in an opened box. Got everything he needed for $325 and he can weld anything he will ever need to on a car. I paid $700 for my welder to do the exact same work he is doing. The downside to the 230v is first off, im really limited to where I can weld. If I wanted to let a friend borrow it, I cant because most of them dont have 230v outlets unless they want to rewire their dryer in their house. I have a 25ft extension cord, 10 ft cord on the welder and 10 ft leads but its almost impossible to reach anything on the other side of the garage. If I had a 110v I could plug it in anywhere. The other downside to a 230v is if you dont put it in yourself, depending on where the breaker box is, you may spend $150+ getting an electrician to run all the wiring. Hell, I spent about $80 doing it myself on materials. What I'm saying is that the extra capabilities of a 230v unit are a waste of money for most hobbyists. Even though I have the money to buy a 230V unit, I would prefer to spend my money on other tools, or possibly a car.1320stang said:Yeah, I think we're just saying, if you can afford a 230v unit, get it, if not, get a quality 135amp minimum 110v unit, don't skimp and get a cheap one. But if that's all you can afford.....
I agree on the versatility and I did mention that in my post. And I have to admit that if I had not found such a great deal (Hobart 180 230V, auto darkening helmet, 25cf cylinder, cart, wire, hammer, gloves, contact tips, and other stuff) more than $1000 worth of material that was original $675 in kit form for close to $500 with tax, I would not have been able to afford it. But I saved enough money that I was able to make a 30Ft extension cord and I made it an adapter as well so now I can plug it into the range plug in with out a problem.xoxbxfx said:lol...no thanks on the tradeI got a 230V because it was recommended to me by a few people here and one of my buddies. Not knowing anythign about welders I took the advice of people and spent $300 more than I really needed to. Do I regret it??? No, but at the time the $300 could have been spent elsewhere. My buddy just to a little Lincoln 110v 130amp from Home depot in an opened box. Got everything he needed for $325 and he can weld anything he will ever need to on a car. I paid $700 for my welder to do the exact same work he is doing. The downside to the 230v is first off, im really limited to where I can weld. If I wanted to let a friend borrow it, I cant because most of them dont have 230v outlets unless they want to rewire their dryer in their house. I have a 25ft extension cord, 10 ft cord on the welder and 10 ft leads but its almost impossible to reach anything on the other side of the garage. If I had a 110v I could plug it in anywhere. The other downside to a 230v is if you dont put it in yourself, depending on where the breaker box is, you may spend $150+ getting an electrician to run all the wiring. Hell, I spent about $80 doing it myself on materials.
230v is nice if you are equipped and have a designated area to weld. 110v is more versitle and easier to move and can still do anything you need on a car.
1320stang said:Ahh, but there is an advantage to not being able to let someone borrow it, LOL!!! It seems like when I need it most, it's at my buddies house.
When I wire my garage for 230v, I'll put in 2 outlets. One will be right next to the panel as it's on my side of the garage. I'll put in a second one near the garage door so I can weld out on the drive if I want. I have about a 30' or 40' extension cord, but it was basically free, all I had to do was buy the plug and outlet and box. While I'm at it, I'm going to wire for the two stage compressor I'm wanting to get, it has a 80 gallon upright tank and I'll mount it outside the side entrance to the garage. I'll build a little lean-to outhouse looking like structure to protect it from the weather. It'll be completely enclosed and insulated, but I won't have to deal with the noise inside. My 110v welder sits on a cart, so I still have to deal with moving it around and I never plug it into an extension cord, I always plug it directly into the outlet.
