What lower control arms to get with my kenny brown adjustable uppers???
jbrown
393
Tallahassee, FL
I just ordered some kenny brown adjustable upper control arms. Which lower control arms do you guys recomend? I was thinking solid lowers, nothing too expensive but I want good quality. Maybe maximum motorsports or steeda? Let me know what kind of control arms you guys have and how happy you are with them. Thanks.
DTMach1 said:
if you just want solid lowers, make sure you get the ones with Poly bushings or Derlan bushings.
I'd opt for the MM double adjustable lowers...
it depends on what your goals are. If you plan on a power adder or hard launches at the track, you want to go with spherical bushings. The poly bushings are not strong enough for this and will fail. I like my pro3i lowers....pretty much the same thing as the mm ones but about a hundred dollars less.
jbrown said:
car is a daily driver, I havent taken it to the track yet but I plan on taking it ocassionally . I just saw the mm are like 340 ouch, I was thinking under 200 hopefully.
check out the pro3i's...they're 155 for urethane bushings on both ends and 185 for urethane on the chassis end and spherical on the axle end
