what modifications would i want to stay away from
I semi agree with stock gears.
Not that I have them. lol.
But They came already in the car, and honestly, I wish I could go back.
BTW, you don't HAVE TO do gears right now. You could always wait till after your install then decided.
Also, listen to Grady, from what Ive seen, he knows whats up or down. :)
whys that?
i was actually looking at them, so its good to know to stay away from them now. because they were ones i was looking at.
because:
1. they are a real pain to work around; it is very hard to get to some of the plugs
2. they burn up spark plug boots. at least mine did, and i even had those heat shield protector thingies on them
3. what little gain there is does not pay for the pain they cause
I think your first ? to BlackVert should've been - Why not?
On a side note. If you buy parts you no longer need you can sell them easily. So not to big of a deal there.
yeah thats basically what i meant by it. like why is that i shouldn't buy them. why not suits the question better though.
and the thing with buying parts that i wont need anymore, is that i'll buy them, and if i buy them new, i'll take a hit when i sell them used.
i won't make my money back on the part, so i'd be losing money. it may only be a couple bucks, but a whole bunch of parts that i won't be using anymore, selling at a couple bucks cheaper, it adds up.
Any Aluminum head will give you thicker decks which is better for boost
and they will flow better as well. They could be some of the older FMS
heads or what ever you can find.
Adequate fuel supply is big intank pump, 42# injs and you'll need a
matching caled meter to go with them.
You'll need a hotter ignition to deal with spark blow out
You know ... common sense things
To make 400 to the wheels ........
You don't need a butch of fancy forged this and that
Of course the choice in rear ratio has nothing to do with the goal but as
you said ... why buy twice so I'd kind of think 355's or 373's since the
blower is gonna be involved.
Since it seems as this is a long term project and budget is a key factor
Just keep you eyes peeled for good used deals on the simple stuff
like headers, tb, and the like.
The point I was trying to make you don't need all the best parts
since the boost can make up for a few misgivings here and there.
If you wanna run NA for a while before boost then you might have to do
a bit of double dipping with things like inj's, maf, and such because what
works good for NA won't be adequate for boost.
Example: I don't see how you could run 42's without a tune
so
You might have to run smaller inj's while NA and the 42's later
Grady
yep i'm always on craigslist looking for good deals locally, seeing if i can find anything to bring me to my goal faster.
so would it be smarter just to wait till i have all the acquired parts to go to S/C instead of ripping things apart multiple times and doing them over.
things like the intank pump and ignition set up i can't go wrong with though correct? like ahead of time before i go forced induction.
i'd like to get this underway this april at englishtown swap meet, pick up some parts for the car to get its to its goal.
because:
ah, so they turn regular maintenence into a hassle.
shorties or long tubes is there a certain one that is better for S/C?
You didn't like Kooks?
Can't say, Ive heard alot of bad about them.
When talking about 94-95 application
1) Kooks hang VERY low
2) They usually leak at the slip joints
From everything I've seen about these headers ..........
they are more of a race type header
I've seen peeps gripe about 1 & 2 for a good many years now
but
They do make power
Grady
but
They do make power
Grady
Thanks. I thought bout buying some. But there kinda costly.
Also, do you have AIM, if so PM me your s/n.
