WHAT NEXT?
BDASPNY
103
HAMPTON ROADS
just got my car out of the shop with tons new stuff. most of which you can see in my sig. also have shorty headers and o/r h pipe newly on. other than a alum rad and a elec fan not sure what next. i was thinking about a upgraded air meter and fuel injectors but was unsure as to what to use any suggestions?
I would ditch the POS BBK T.B and get a good one, i broke the butter flies on mine and seen 4 others with the same problem or they stick either way BBK products are junk! Go get a pro products or a acufab get a 75mm and a C&L 76mm mass air. I think with what your putting down power wise the 24's should be fine, if i remember right the line for the 19's is around 300hp. 30's would be to much unless you going boost! If ya get the 24's before or even after the C&L make sure you get the right calibrated tube for it for the injectors peace
john:p
