WHAT NEXT??? =)
vladasap
294
nyc, ny
Hey guys, I have a rio red 95 gt with the following - CAI, bbk headers, full exhaust, bbk u/d pulley kit, short shifter, king cobra clutch, shorter belt (smog delete) but I want moreeeee power and/or speed =)
My budget is low but i want a fairly cheap mod with a good diff in power
any suggestions??? -how would a cobra mani work and can i just pick one up n swap it with mine or...?
*if u guys can gimme some numbers that be great (prices and gains)
THANKS IN ADVANCE
thanks for that ... seems a little complicated so im gonna have to find someone to do it for me or show me how to do it because i dunt wanna make a mess
but how much are gears w/install and which ones should i go with my setup ??
my guess is 3:73s will do good?
The spark advance is pretty easy once you get into it - just need a timing light and a way to loosen the distributor hold down.
You can do a search and read miles of threads about what gears to go with.
General rule of thumb is this: 5spd tranny - 3.73, Auto tranny - 4.10, Forced induction - 3.55.
Wes
how did I not think of that ??!!!
theres this kid in my neigborhood with a civic with over 1000 bhp when u add up all the sticker, lambo door and HUGE exhaust mods ....
I hear he is going to be dyno-ing over 1300 bhp after the body kit tho
ill keep u guys posted !!!
any suggestions???
Gears will most definitely give you ... a good diff in power :banana:
As for your low budget .......
Gears will give you the most performance gain for the amount of dollars you will spend ;)
I can't stress enough how effective they can be :nice:
Lemme say it this way :D
You would be better off NOT doing a couple of mods together like mid pipe/pulleys or tb/rr's or similar mods like those that don't really give all that much of a gain.
Even though
You could do each of those kinds of mods one at a time which is more suitable to a low budget situation .........
Resist the temptation of that method and save beyond the amount needed for just one of those low gain mods and keep saving for the amount needed to get the gears.
You're discipline of sticking to the plan will be rewarded with a good deal more performance by going with the gear mod ;)
THANKS IN ADVANCE
A Cobra or aftermarket intake will NOT EVEN COME CLOSE to the gain you will obtain from a set of gears :nono:
For that matter ...............
NO single motor mod will do for you what a set of gears will :eek:
Well maybe Juice
but
Thats a mod that keeps on getting more and more expensive which seems to not fit in with the info you've given us.
Grady
+1 for 3.73's, you'll love 'em!!
Bump the timing no higher than 14 degrees for the street.
Like Grady said, throttle bodies and roller rockers won't help unless you have upgraded heads, cam, and intake. However you can pick up a used Cobra upper/lower intake for pretty cheap, it won't hurt to have a little extra air going into the engine with your exhaust system.
Basic maintenance is a given, clean the mass airflow sensor, fuel filter if needed, and make sure your spark plugs are gapped correctly, or replace them along lower resistance plug wires and new rotor- I did this and felt a very nice difference in throttle response.
You can also run SeaFoam through either the fuel system (pour into gas tank when you fill up), or through the PCV valve. It cleans up the internals and helps keep a steadier idle. There are some threads on here about how to do it.
