What psi for nitto drag radials
WhiteTrashGT said:
i daily mine on 20psi, and the first set last me about 8 months. I dont do a lot of burnouts though.
Thats too low for daily driving. Put them at 30-35 and you will see more life. Put them at 20 for the track.
And im looking into getting soem 17's to throw those M/T's on. :)
millhouse said:
If you run them any higher than 25 your tread will prematurely wear in the center section of the tire. Keep them between 20-25 for daily driving and lower em down to 15-20 for track duty.
I agree. If you try 30+, be prepared to have no center after a short while.
And as far as hooking, it doesn't matter, b/c they don't hook good at any psi in my opinion.
  • Useful
Reactions: revhead347
Get ready for bent axles. I ran NITTO drags on my stock ponies up until I launched it from a stop light against a honda and bent the passenger axle FUBAR.
Unless you have an aftermarket diff and axles.
Drag radials are not good for daily driving. Period.
Adam
I also agree. Do NOT run these things in the 30lb range, if you do you will have a no center section left and plenty of outside tread.
Adam
It sounds like you had some wheel hop...as bent axles are not the norm. I don't think I've ever heard of any ever even snapping an axle using nitto's...they just don't hook up as well as other drag radials. I myself am finished with my 3rd set with no issues. I've had several hundred dragstrip runs....again with no axle issues.
I don't know man... I just ran them at 25 psi and they hooked like a bastard. My axle got bent, didn't snap it.
Just throwing it out there, real life experience and something the poster should be thinking about. Its possible I was the exception... but I don't think stock axles and diffs are designed to take that kind of stress.
.02
