- Oct 25, 2007
- 92
- 1
- 9
I have a 92 notch. Mods include;
AFR 165 heads
Edelbrock performer intake
76mm C&L Mass
75mm TB
Steeda cam #18 or #19 (not sure witch one)
1.6 RR comp cams
I cant decide what injectors will be the best according to my mods 24 lbs or 30 lbs?
plus can you guys let me know if the stock fuel pump would work both injectors, I know I would need a pressure regulator but not sure about the fuel pump, I heard that the stock fuel pump will work for the 24 lbs but for 30 lbs maybe cutting it short, but I don't know, that's why I'm asking all you. Any help would be appreciated thanks in advance.
:SNSign:
AFR 165 heads
76mm C&L Mass
75mm TB
1.6 RR comp cams
:SNSign:
