What size TB do I need?
BelueLX
1,195
Im trying to decide between 65-70-75mm throttle bodies. Im running a Vortech SC-trim @ 11 psi, Typhoon intake, full exhaust, 73mm C&L MAF and a 50-shot. Im about to buy some alum heads (probably AFR) once I get a TB and a few more supporting mods and swap to a turbo setup. Thanks,
Cody
The TB size with a forced induction motor really makes no difference...between 65mm and 70mm...Do you want more throttle response in lower RPM's? if so go with 65mm if 70 would be my choice since it works well with the intake opening...75 WAY too big...
The turbo setup since its what Im about to have. Im going to basically launch at 3500rpm and shift at 5750 almost like I do now if it will still hook
