what size tires to get?
ok.. ive got some 17x10.5 inch rims on their way here. the bullet deep dish's for my stang... what size tires should i put on them? i want something that wont wear down so fast but also will grip traction.... here are my mods....
BBK LT headers
BBK catted X pipe
Borla Catback
FFRP 3.73 gears
Blu thunder short throw shifter
75mm accufab TB and C&L upper plenum
90mm lightning maf
42lb ford injectors
superchips flip chip
Aftercooled Vortech @ 10psi
homemade boost pipe
spec stage 2 clutch
aluminum upper and lower rear control arms
eibach pro springs
full sub frame connectors
relocated battery to trunk
i was looking at drag radials but im not to sure if they will wear to easily... i need something that will last me atleast 5 months. these tires i have on now have gone like 7 months so far and only have another thousand or two left of on them.
these will be street tires and the car is pretty much a daily driver... right now i dont get traction till 4th gear. :bang:
Depends on your budget and size you want...I'm not an expert, but this is what I've pretty much came up with in my exact same search...Go to tire rack for more info.
315/35-17:
(Best Bet)
BFG DRs
Goodyear GS-D3s
(Cheaper alternative)
Sumitomo HTRs
285/40-17:
(Best bet)
BFG DRs
Goodyear GS-D3s
Kumho MXs
Edit: Forgot about Nitto 555s
From chatting with people on the forums Ive heard that 315's may rub. Depends on the car and the exhaust. Probably just a little work with a hammer and grinder or some cutter will fix that. Dunno if yer up for that. Or you may be one of the many that dont have issues. I also should be getting some 17x10.5's soon. I am looking at 275 or 285 40's since I know those will fit. I know many people also run 275/40's up front, but Ive heard those can rub. Since I want to do a little auto-x and club track events I'll probly stick with 245's in front. I have had success with BFG's and Yokohama tires. The Nitto's are good but a drag radial wont last as long with its reduced tread depth, and not sure how well it will do now that winter is coming.
trailblazr81 said:
From chatting with people on the forums Ive heard that 315's may rub. Depends on the car and the exhaust. Probably just a little work with a hammer and grinder or some cutter will fix that. Dunno if yer up for that. Or you may be one of the many that dont have issues...
:bs:
On my 03 Centennial Vert have 10.5 deep dish bullitts with Goodyear F1 GS-D3 315/35/17s and there is NO rubbing. No problems with clearance with either the stock catbacks or with Steeda catbacks (made by Borla). No rubbing with fenders at all. Grip both wet and dry is FANTASTIC!!! :hail2: Here's a few pics.
Before (245/45/17 Gatorbacks)...
photodisplay.php
After (F1 GS-D3 315/35/17)
photodisplay.php
A$$ shot...
photodisplay.php
Side view...
photodisplay.php
skidad62 said:
:bs:
QUOTE]
no he is correct but it is catback/wheel offset issue IMO. deadlurker had an issue with his bassani catback and 10.5 with 315's. There are many people running this setup with no problems so as long as the rim offset/ tailpipes are right they won't rub.
racer02gtstang said:
i wonder if i would rub any since my car has a drop on it? ive got the eibach pro springs... should i still be good with that? do the tires roll over any on the rims?
drop is not really going to matter. it is the passenger side tailpipe that is the issue. where it is at the tire is going to be by it no matter what your ride height.
skidad62 said:
:bs:
Which is why I said MAY RUB!! Yours doesnt. Many other dont. Some do. Depends on the car and the exhaust...
