ok i drive to work by streets, do i waste more gas driving at 40 in 4th gear at 1.8k rpm or driving 40 in 5th at 1.3k rpm?? also, is it true when engine braking, no gas is being burned above 1.5k rpm??
rpm is not the whole cause of it, it's to do with throttle position.Black Stang 97 said:ok i drive to work by streets, do i waste more gas driving at 40 in 4th gear at 1.8k rpm or driving 40 in 5th at 1.3k rpm?? also, is it true when engine braking, no gas is being burned above 1.5k rpm??
300bhp/ton said:And yes, with the throttle plate closed no fuel should be being injected into the engine, so coasting in gear down hills or up to junctions can save you fuel, although it doesn't quite work the same for autos due to how automatic gearboxes work.
Huh?300bhp/ton said:And yes, with the throttle plate closed no fuel should be being injected into the engine, so coasting in gear down hills or up to junctions can save you fuel, although it doesn't quite work the same for autos due to how automatic gearboxes work.
they work the same in many respects.sgarlic said:Although I'm no genious, I have to disagree. An internal combustion engine takes gasoline to run, and when you engine brake, the engine is still running, regardless of the fact that all it's doing is slowing you down.
If perhaps you're thinking of a deisel engine which uses compression to slow you down, then you'd be absolutely correct.
1st off rocket science is actually very simple, in it's basic concept. Rocket motors where developed YEARS before internal combustion petrol engines, even before steam.twogts4us said:Huh?![]()
So, when you start the car with the throttle plate closed, it uses no fuel?
OR, when coasting in gear (or out of gear for that matter) downhill, does the engine magically stay running with no fuel?
Didn't we address this whole issue a week or so ago? This is so silly. The answer to the thread is 'the lowest RPMs you can go' will net you the least amount of fuel used. Not rocket science here people. And please save your breath if you want to split some technical hair that may save another 1/100th of a gallon of fuel per million miles...it just doesn't matter. The best mileage, when cruising at highway speed, is achieved in the top gear.
Redsnake2 said:0000mph would be my guess
True if the engine is not on. If the engine is on then you get 0mpg
"This isn't rocket science" is a figure of speech, not to be taken literally...300bhp/ton said:1st off rocket science is actually very simple, in it's basic concept. Rocket motors where developed YEARS before internal combustion petrol engines, even before steam.
So you are saying if you are in gear and coasting, the engine just free wheels??? And then if I push the clutch in, it's magically starts running (on fuel) again??? Come on...300bhp/ton said:As for the engine running at idle or coasting in N. Yes here it requires fuel, as it is the combustion that foces the cylinders down generating rotary motion.
When coasting in gear, the engine is connected to the wheels via the gearbox, which are in contact with the ground. Gravity, or rather the stored potential energy being turned into kenetic energy as the car coasts turns the engine over, thus there is no need for any fuel. This works on carb engines too.
you don't have to believe me, but why not do some research and look it up! This is not a new concept, internal combustion engines have been fairly common place since the early part of last century.twogts4us said:"This isn't rocket science" is a figure of speech, not to be taken literally...![]()
So you are saying if you are in gear and coasting, the engine just free wheels??? And then if I push the clutch in, it's magically starts running (on fuel) again??? Come on...![]()
