what speedo gear?
kreacher5.0
122
What speedo gear for 3.55s with 4banger t5 the gear thats in it was for the 4banger wich was 3.45s it doesnt seem to be off much if any but just making sure any help would be great.
Manual Transmissions with 6 Tooth Drive Gear
Not found in OEM applications
Item Number
Description
N/A
3.08 Gear Ratio / Not possible
C0DZ-17271-A
3.27 Gear Ratio / Maroon 16 Speedo Gear
C3DZ-17271-C
3.55 Gear Ratio / White 17 Speedo Gear
C0DD-17271-B
3.73 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.90 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
4.10 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
4.30 Gear Ratio / Red 21 Speedo Gear
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Item Number
Description
C0DZ-17271-A
2.73 Gear Ratio / Maroon 16 Speedo Gear
C0DD-17271-B
3.08 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.27 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
3.55 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.73 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
Item Number
Description
C0DD-17271-B
2.73 Gear Ratio / Yellow 18 Speedo Gear
C1DZ-17271-A
3.08 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.27 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
3.55 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Item Number
Description
D0AZ-17271-A
2.73 Gear Ratio / Blue 16 Speedo Gear
C7AZ-17271-B
3.08 Gear Ratio / Gray 18 Speedo Gear
C7VY-17271-A
3.27 Gear Ratio / Tan 19 Speedo Gear
C8SZ-17271-B
3.55 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.73 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Item Number
Description
C7AZ-17271-B
2.73 Gear Ratio / Gray 18 Speedo Gear
C8SZ-17271-B
3.08 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.27 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Now if you really want to change the internal drive gear of your manual tranny you can match it according to the table below. Be aware that the 6 tooth will offer the most combos for numerically higher gear ratios and offer the greatest degree of accuracy. The 6 tooth gear selection table for a manual tranny is the first in the page.
Item Number
Description
E3ZZ-17285-B
6 Tooth Internal Drive Gear / Black
E3ZZ-17285-A
7 Tooth Internal Drive Gear / Yellow
F0ZZ-17285-A
8 Tooth Internal Drive Gear / Green
