What spindles do i have
  • Thread starter Thread starter jb1dsl
  • Start date Start date Nov 12, 2004
jb1dsl
566
Marianna, Fl.
Nov 12, 2004
  • Nov 12, 2004
What brakes do i have? help!!
i got a disk brake setup from a friend for free today. He said they came off a 66. i picked them up and when i got home the rotors looked different. Everything else looks the same. they are the right dual piston type. One rotor has square holes on the hub and the other does not. see pics. i was wondering is there a way to tell if i got the right setup. Can later model (68and up) rotors be put on a 66 spindle? I will try and get pics of the whole setup tomorrow.
rbohm
6,698
550
204
tucson,az
Nov 12, 2004
  • Nov 12, 2004
both rotors look the same except the first pic rotor is a two piece rotor that was common on disc brake stangs through mid 67. either rotor will be fine as the later replacement rotors for the 67 and earlier cars is a one piece rotor.
Billgear
500
Concord, CA
Nov 13, 2004
  • Nov 13, 2004
Most of the rotors are the same, the only difference is the wheel bearings and races. Make sure they fit correctly and the wheels bearings seem to be the correct size.
jb1dsl
566
Marianna, Fl.
Nov 13, 2004
  • Nov 13, 2004
so maybe the rotors were made by different companies. is there some knid of numbers stamped on the spindles or anything to distinguish 65-66 spindles?
So the one piece rotors will work?
what master cylinder should i use, a 67 for disk?
did ford make a master cylinder in 67 for manual/disk?
jb1dsl
566
Marianna, Fl.
Nov 13, 2004
  • Nov 13, 2004
Also can i put a master cylinder and brake booster on my car from a 67 with power disk brakes
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
