What stock engine parts are aluminum?
I'm going to do a long over due engine bay cleaning with Simple Green, and wanted to see which parts were aluminum. I want to spray those parts separately to make sure i don't cause any damage.
From what I've read the Upper and lower intake bodies are aluminum. Are the pullies as well?
thanks,
most everything from the timing cover forward is aluminum: timing cover, ac, ps, smog pump, alt, wp, tensioner, upper and lower intake, t-stat housing, and the bracket for the smog/alt (the ac bracket is steel). stock valve covers are also stamped steel.
maf housing is also alum.
